New WoodChat!
Deep Splinter
Deep Splinter
Deep Splinter
david weaver
About two months ago, I got a deep splinter of black palm right in the end of my middle finger. It went in and right along the bone.
The end of it was sticking out of my finger (the long splinter was about an inch long with about 3/8ths or a little less sticking out of my finger - maybe a quarter. When I grabbed the splinter and pulled, it snapped off and as far as I can tell is about 1/16th below my fingertip, maybe 1/8th. It only hurts when something presses it and it gets irritated if I do something that doesn't press it (like planing). I've been waiting for this period of time to see if it will surface or move a little bit to be easier to get, but no dice.
Thursday, I'm getting it removed. Has anyone else been down this road? I'm assuming that given where it is, I'll get sliced up pretty deep and I'll be down for the count as far as hand tooling goes for a while, because it's on my dominant hand. It's going to make writing and typing a bear at work, too.
Right now, it's straight in and runs almost along the bone, I can see it with a bright flashlight. I'd like to remove it myself, but I don't quite have the will to cut live tissue deeply and my wife would have a fit if I did that.
Re: Deep Splinter
Re: Ouch!
david weaver
I was thinking how enjoyable the floor scraping was as a release, and looking forward to doing the next much larger area sometime!!
We have kids and carpet, which is a good combination, I suppose (not for the floors, but for their knees, elbows and heads). When they get a little bit older, the carpet will be worn out and I will have the chance to scrape more.
The palm wood splinter is about as big around as a toothpick, it is amazon how your brain will set the sensation of it aside after a while and only remind you that it's there when you put a fairly substantial amount of pressure on it.
Re: Deep Splinter
Been there....
Brian Roberts
and since I refuse to pay many hundreds...if not a thousand plus dollars...I "do it myself".
Numb thoroughly with ice...quick slice with a new, sterile exacto blade...the long pointed one works for me.
I do a "rehearsal"....so to speak...mark the spot to cut with a sharpie.....poke the blade in and "flick" it out in a cutting direction.....quick and fairly painless.
Then in with the tweezer.....
Not for everyone....I know....
Re: Deep Splinter
Re: Been there....
The problem with self-surgery, Brian, is that it is a little like the chicken-and-the egg question ... what comes first - the half bottle of Scotch beforehand, or after.
And ... if digested beforehand, are you still able to see your hand, never mind the splinter. But .. if you can still see the splinter, clearly you have not had enough Scotch!
Re: Deep Splinter
Re: Been there....
david weaver
I've given the slight slice with a sharp knife to this one, but it's far too deep - along the bone in my finger. It's tapered and will need to come out the way it went in. It may need to be stitched if they have go fillet most of the length to get it unstuck from whatever it went in against.
The strange thing about when it went in, it got stuck in so hard that pulling it straight with a pair of pliers broke it off with a "thhhpppp". Whether that's because it was partially broken in the middle of my finger, I don't know. I wish I'd have taken a little more time trying to get it out on the first go around to prevent it breaking off.
The other trouble in the minor slice is the blood flow - it quickly gets in the way. I pondered giving it a try in the shower (where the blood flow would quickly go away), but in this case, I have a no-deductible health plan with a $25 copy to specialists, so I'll just let the docs do it.
If I had a large deductible, I'd think a little bit harder about it.
Re: Deep Splinter
Re: Been there....
Brian Holcombe
ouch! But better to let them take it out. So far my worst WW injury has been with a flush cut saw. My wife was very angry that I taped it and went back to work, which I did end up regretting as the finger was throbbing that night.
So, I feel your pain!
I was out for a few weeks two years ago with a hernia repair, I found it difficult to truly wait out the recommended eight weeks.
Re: Deep Splinter
Re: Been there....
david weaver
Me too on the prior cuts. The worst shop injury that I had was quite a while ago when I was first trying to speed up work with japanese saws. I pulled a large gyochuko ryoba out too far and it landed on the thumb of my forward hand and went for a bit more of the stroke after that. Didn't go to the bone, but chewed up a lot of the meat.
I did the same as you, wrap it up and go. My favorite thing to do with cuts is hold them above my head for a minute and then glue them with CA.
Re: Deep Splinter
Re: Been there....
Brian Holcombe
It's amazing how fast Japanese saws cut!
Re: Deep Splinter
Yup.....
Brian Roberts
for $25 I would let em do it.....
Re: Deep Splinter
I have become thankful for health insurance....
....as a result of this discussion.
My grandmother worked on a spinning machine where wooden bobbins were wound . A piece slew off and embedded into her hand. Some years later it emerged and she pulled it out. It made a lasting impression on a 6 year old.
Re: Deep Splinter
Re: I have become thankful for health insurance...
david weaver
I know for sure my grandfather never would've paid someone to take it out. he'd have waited for it, and if it didn't come out, so be it.
My concern with waiting on this one is that it's in my fingertip on one end, so there is always going to be pressure on it pushing it back in (of course, I read about these a little to see if it was something I could dig out and how long it would take to surface). I sounds from what I read like there are a lot of people with splinters in their feet, and those have the same problem - they can be large and irritating when jostled, but they don't come out because they keep getting stomped back in.
I never did go to the doctor much until I had kids, but now if I ignore things, my wife makes my life worse than just going and getting them solved.
Re: Deep Splinter
Brian Holcombe
Hah, we share that last bit in common. The mental pain is sometimes far worse.
I used to do metal work (and still do but far more casually now) and metal splinters are truly a PITA. I'm almost certain I still have a few that just never seem to come out.
Re: Deep Splinter
two months on and no infection
ian neuhaus
you've been very lucky
Re: Deep Splinter
Re: two months on and no infection
david weaver
I figured that at some point, infection might occur, and help push the process along, but no such luck.
Re: Deep Splinter
TomD
How do the kids fit in, do they back her?
They always say that you should seek medical attention where fingers are involved, too much going on. I was tying flies once, and a 6 pound pedestal vise and impaled myself on the end of the hook and found myself humorously tacked to the vise. I just ripped it back out, but it was nothing compared to what you have going on. To state the obvious.
People can follow up if they wish and google images of "arrow through hand". Sometimes the arrows break in the bow, and sometimes people pull them too far back in the bow... Not a good day at the range when any of that happens.
Re: Deep Splinter
ian neuhaus
an infection would almost certainly have hastened your visit to the ER
Re: Deep Splinter
david weaver
If the movie Frozen and Cars are not included, then the kids don't have an opinion. You can only see the splinter at this point if I candle my finger with a flashlight, but it's blurry!! If it was a clearer outline, I'd have a better idea of whether or not I could get it myself.
I didn't do anything in the shop over the weekend, just outdoor work, so weeks like this week where I'm not picking something up, I don't even notice it and kind of wonder if I should just leave it alone.
A week of pulling up carpets and redoing floors again would make me aware of it, though.
Re: Deep Splinter
Re: Been there....
David weaver
As I sit and wait in the Dr's office while they make a mountain out of this molehill, xrays, etc, possibly rescheduling to remove it, self service is looking like a better idea.
Re: Deep Splinter
Re: conclusion...
david weaver
...separate surgery at a surgery center, incision in the end and stitches, no guarantee of removal (that would require a full length incision that would leave damage), but should be able to get a hold of the end and pull out as much as possible and leave in whatever breaks off.
Re: Deep Splinter
Good luck!
Re: Deep Splinter
Re: Thanks, Hank
david weaver
I don't want to make it out to be a big deal, it's just a splinter. I'm at a loss as to why it takes so many stops at various offices just to get it removed. I guess the medical community is just overly cautious these days whereas I'd take their 15-minute good old college try and take my odds with that and call it OK if they can't get it out.
Sort of feels overdone.
The stupid thing about it is that I rarely sand anything. I got this sanding something that I was just experimenting with (planing black palm), and I was only sanding the surface to compare.
