Depth Stop on Moving Fillister Planes - how High?
david weaver
As I'm planing out trim pieces to go from the carpet to the floor and from separate floor services, I got out a wooden moving fillister plane that I haven't yet used. Long story short, I had a common us maker fillister that was a bit worn out and sloppy and replaced it with a little used english maker plane.
When I went to set the depth for a rebate for the carpet (7/16th high), the depth stop on the plane couldn't come remotely close to that. It ran out of travel around 1/4th of an inch. I lost my temper and turned it out, figuring if that's all the higher it will go, I will take it off of the plane (that part is true).
The other plane I had (which I should have kept) had much more travel.
Is there a typical amount of travel a moving fillister has on the depth stop (especially the type that are screw adjust)? what good would it be if it's only 1/4th of an inch? It has to be common to cut 3/8th or 1/2" high rabbets to nail T&G in the back of the case.
The wood I'm working is second growth oak, which is fairly hard, and though I sold my old fillister plane, I still have a metal one, and I used that. For bulk work and a heavy cut, though, a wooden plane is at least twice as easy to use.
I will have to repair the plane that I mauled, the threads are certainly stripped now, but it's of very little use with that kind of depth limitation. Taking it apart will answer the question of whether it was jammed or actually at the end of travel.
If you have a woody fillister, can you do me a favor and see what the maximum height of the depth stop foot is above the plane sole?
(there are other options for this, of course - but I'd rather not set up the power router table for this work, and just using a rabbet plane in wood that is hard even for oak, it's slow going. )
