New WoodChat!
A55 Smoothing Plane
The Butler's Desk - Desk Drawer
Brian Holcombe
Good morning! The main desk drawer on the butler's desk is now completed. You may notice a departure in how this drawer is made from the typical, being that I have through tenons at the back of the drawer and extensions on the sides.
https://brianholcombewoodworker.com/2016/07/07/the-butlers-desk-desk-drawer/
Please click the above link to see the full article
Re: The Butler's Desk - Desk Drawer
Question
This desk seems to be designed for some purpose. I probably missed it at the beginning but where is this all headed? How will it be used and what goes in there that needs wiring?
Re: Question
Brian Holcombe
I'm considering starting out my next multi-post build with an image of the design so that it's a bit more clear my intentions. What are your thoughts on this?
The desk is designed to be a work station for a home, allowing all of the paperwork and electronics to be concealed. Sometimes it's nice to leave out paperwork which is not yet completed but that you don't want to see, so it can be left inside the case and returned to when time allows.
The intention is for the desk to appear as a cabinet when not in use. There won't even be a chair near it, but basically brought over when needed. Electronics will be able to be left in the case to charge overnight.
I go into greater depth on the blog, and many many more pictures (and sometimes videos!).
An easier solution.....
"The desk is designed to be a work station for a home, allowing all of the paperwork and electronics to be concealed." .....solution, a door. In my case it takes a room to contain the clutter :) :) !
I like the preconstruction plan and description idea.
Report back in a year how the drawer to support the drop front works out. Historically, two pull out supports were used to support a drop front thereby providing more leg room under the drop front for a chair.
Re: An easier solution.....
Brian Holcombe
Hah! It is difficult sometimes, my study is minimalist and so my wife likes to plunk something on my desk every once in a while to see the effect of OCD!
I wont need to report back in a year. :D I've been using a desk with similar clearances for five or six years now.
My client has as well, his dining table is similarly skirted. Luckily we both own the same chair, so I have set it up to work exactly with the same chair.
I plan some folding stays as well, hopefully they're as good looking as they appear online.
Same with the lock. Why is it that hardware is such a PITA! Before I'm done I'll likely have locks to view from every manufacturer that makes cabinet locks, lol.
I don't know ....
but I agree.
"Why is it that hardware is such a PITA!"
My one example of PITA hardware
Wiley Horne--So. Calif.
I needed a lock for a Krenov wall cabinet. Just a smallish lock--what could go wrong? My problem turned out to be the key--specifically the length of the key.
I needed a key that was sorta short, so I could just leave it in the lock as an ornament (and so it wouldn't get lost). I liked Lee Valley's selection, and ended up selecting this lock:
http://www.leevalley.com/US/hardware/page.aspx?p=40640&cat=3,41427,41385
I like the lock a lot. But the key was too long to look tidy when left in the lock. So I went around the internet, and scrounged up a shortish key that had approx. the right-sized flag on it. Then filed the flag to work.
I think the general answer to Brian's question is that hardware is all about a zillion details, and if you're picky, one of those details will be just a little bit wrong for what you're trying to do. But then I may be exactly wrong :) .
Wiley
Re: My one example of PITA hardware
Brian Holcombe
Exactly! There is always something. Honestly if this next lock doesn't work I'm doing to dissect it and make my own.
Also...why in the world do they only come in brass! I used stainless for hinges and yet, the best solution is that I make my own plates, the likely solution is that I oxidize these brass blacks and live with a combination blade and stainless.
Our opinions diverge
Stainless on walnut? Nope! Brass was made for walnut. Stainless is for plastic and metal furniture.
Re: Our opinions diverge
Brian Holcombe
Client's request.
I've been given artistic license on the entire project less the color of the hardware, I can live with that.
Also
my favorite hardware place, Londonderry Brasses, has steel locks and some kind of white metal escutcheons. Call Nancy (?)to find out.
Re: Stainless lock $$$
Brian Holcombe
I bought a neat lock set on using it....it's a jewelry box lock which means it has a hook rather than a bolt. It would need to be a zero clearance fit to work since a jewelry box lock is made to cinch tight.
So back to the drawing board I bought an English made cabinet lock with a bolt, but have yet to have it in hand to inspect the quality.
TomD
I think nickle silver and naval bronze look pretty nice. If you heat stainless you can get pretty nice range of colour out of it. You can get a nice regular bronze shade.
A looming electrical porblem
Given the attention to detail in this piece I am suspecting that attaching an outlet strip from Walmart to the back of the case for a power source will not be satisfactory. So how does one provide power to something elegant so as to not detract?
Very nice!
Tony - Memphis
Your work is inspiring. Underneath of mine - it is evident that a butterknife was used! Ha!
Tony
Re: A looming electrical porblem
Brian Holcombe
Our debate (both the client and I) is wether or not to mount a strip in the wall behind the cabinet (preferred) or to mount a strip on the back underside of the cabinet (between the drawer and back framing member).
As far as the power strip goes, I'll find something decent. I have in mind something akin to those used in commercial partitions.
Re:Solar Panels?
I'll start drilling pilot holes today
Re: I'll start drilling pilot holes today
William Duffield
Hey, we're in New Jersey. You'll need a power pole to mount the panel on. :D
CJ in MPLS
When the kitchen was remodeled (I chickened out on doing it myself) I sketched out niche for a wall phone in the kitchen. Yes, it doesn't get used by any except telemarketers I think, but it looks good and gives us a place to set cell phones and connect them to chargers. We installed a removable till or set of drawers with a small pass through for chargers. The chargers are plugged into a Leviton combination outlet that has two USB ports and two standard 110v outlets. I would take a moment to consider whether you could wire up such an outlet in an out of the way place and run a cord with a plug to power it. Strong work on the cabinet by the way.
Brian Holcombe
Thank you CJ!
I'll keep those ideas in mind.
