New WoodChat!
REAL MILK PAINT
Meanwhile back at woodworking.....
Occasionally I take a break from armchair woodworking and build something, in this case a bedside chest of drawers for Granddaughter. I pushed to get it ready to finish . She is visiting tomorrow and she will finish sand and stain it. I'll then spray it with varnish.
Then...I am working on two Danish Modern bedside chest of drawers for daughter and her husband. These would have gone together straightforward with modern joinery of loose tenons. But I refuse to pay the price of a good used table saw for a Festool to make them. I missed a chance to get a horizontal mortiser. So I forged on with conventional joinery.
As one can see there is a lot going on at the corner posts. But I got the side panels together and nothing wound up backward, upside down, inside out or all the other permutations of what could go wrong with this complicated assembly. Son in law is inexperienced but he has "good hands" and we will work on these pieces this weekend during visit (and do some shooting). [
Re: Meanwhile back at woodworking.....
Brian Holcombe
The Chest came out great! How dark will she stain it?
The Danish style bedside tables look interesting, excited to see how those go together.
What is a floating tenon :b ;)
my typical cherry stain.....
It is a mix of two General Oil stains which are a pigment stain. On my monitor the picture is a bet redder than reality.
PS... a tip
Note the shelf liner under the cherry piece. This stuff is great on the bench to protect surfaces under construction and keep them from skidding. Pieces of stuff that might scrap or ding the wood fall through the cracks where they become harmless.
Some of the new material has an "oil" (probably plasticizer) that can "wet" the wood. A good dusting with sawdust eliminated this problem and it goes away with time anyway.
Re: PS... a tip
Brian Holcombe
That's slick, I noticed you use a shelf liner for your skid-free honing plate pad as well.
I usually hate stains, but truly your cherry stain is very nice looking. As expected, stains that are well done are a compliment to the work and material.
the secret is the sanding
I can't successfully stain a hand planed piece with a mineral pigment stain. The open grain drinks the stain and the result is ugly. Just the right amount of perfect sanding partially seals the wood and the stain goes on uniform and transparent. There will be intensity variation with grain variation, which is usually good.
Re: the secret is the sanding
Brian Holcombe
I can see that being an issue, I always have light scallops in my panels, even when they look perfectly flat in photos, if you run your hand over them you'll notice the scallops.
other stains
Chemical and dye stains will work on hand planed surfaces, and indeed did work in their day. I will not use chromate for a variety of reasons and all these reasons are worrisome. Something proven to be a respiratory carcinogen even outside CA that will be attached to the inevitable wood dust is one of the worries. Cranky neighbors that could have you put in jail for improper storage and use is another.
I have not learned to use dye stains, synthetic or natural. A lady stained some rush for me with walnut hulls. The result was attractive and the stain has been stable in a sunny room.
Re: other stains
Brian Holcombe
Thanks for that tip. Even though I do not stain, it is interesting to know because on a rare occasion I think about it doing so (dark table base, for instance).
My main reasons for not doing much sanding (I do sand things on a very rare occasion) and avoiding chemicals are a basement workshop. I have lamps that overhang the sharpening bench and it is encouraging to see that they do not get dusty at a rate which greatly exceeds the dust accumulation of any other area of the house.....all of which get dusted of course. :)
