more on charging diamonds to cast iron
This picture sums up my set up. The plate goes on a skid-free shelf liner. Diamond can be either in a paste or loose in a vial. The loose in a vial is cheaper but less convenient. A squirt bottle of WD 40 for lube. And finally, just tried a ceramic stick to rub the diamonds into the plate. It is hard to say if it worked but it did spread them around nicely.
Best of all the learning curve is not high or steep. There aren't any variables. Anybody can do it. Stuff I sharpen this way cuts wood so what more can one say.
PS the vertical scratches on the bottom of the plate is what happens when one tries to remove the tenacious burr on a 3V blade by rubbing the back on the plate. Currently I just grind the burr away by abrading the bevel with 1 micron paste. In the case of 3V it gets thin and just floats away.
