Charging a cast iron plate with diamonds
Diamond charged on cast iron and lubed with olive oil has been used for centuries for polishing gems, including diamonds.
I was told by a gem cutter to add the diamond paste (oil based) to the cast iron, spritz with olive oil, smear around by some means and embed by rubbing with a curved inexpensive stone like sapphire. I was to receive an appropriate sapphire but never got it. I think any stone with a radius surface would do acceptably, but I don't have one.
What I in fact do:
Squirt about 1 cm of paste onto the 12" long plate. Most beginners use way too much paste. I actually distribute it about the plate for a total of about 1 cm or less. I add some drops of WD40, wrap my index finger in a condom made from a piece of plastic grocery bag (I am unsure what those in CA will be able to do), and smear the paste about the plate.
At this point it would be ideal to then rub a stone on the plate to embed the diamond. I don't have one so I rub what I need to sharpen. From time to time I return the liquid, that no doubt contains some diamond, that gathers on the metal back to the plate.
When I am done sharpening I wipe the plate with a paper towel and return it to a plastic bag. I do not recharge every time I use it. I do lube with WD40 as its viscosity is just right.
