New WoodChat!
Diamonds
Diamonds
Jack Guzman from Maine
Diamonds
I've been putting off exploring the world of diamond abrasive sharpening long enough. There is just so much info out there I don't know where to start.
I'm going to purchase a few different grits to get me started. I want to use it for final honing,after grinding and for touch ups between sharpenings. At the moment I'm mainly interested in keeping my carving chisels sharp. I use several different gouges for chair work and they need to be sharp.
Can I get a few pointers,suggestions to help me get this started? I don't know how diamond pastes are rated for grit. Are the larger numbers coarser grits? What is the micron equivalent to 1000 grit,etc.. ---Jack
Re: Diamonds
Re: Diamonds
John in NM
Larger numbers are coarser grit - but there are a few different systems of grit size. I believe the most commonly used is mesh grit (or perhaps that is the one I'm most familiar with because we used to use it in geologic sampling). Best to stick to micron if you can and look for a grit-micron conversion table on the web just in case you can't - not all suppliers list micron size.
1200 mesh is about 15 micron.
Re: Diamonds
Re: Diamonds
I saved that one to print out. thanks---Jack
Re: Diamonds
Re: Diamonds *LINK*
John in NM
Sometimes extensive is not necessary :D
Most diamond suppliers seem to use either micron or grit (which is basically the same as sandpaper). The trouble is I've seen references to "grit mesh" to distinguish it from all the other grit systems, some of which have wildly different numbers.
One can only assume that the various grit systems were attempts to improve upon a pretty loose and empirical older system rather than just accept reality and use micron sizing instead :D
I'm not sure what level of polish Jack needs, or what grit will get him there. In lapidary work, an acceptable mirror polish is 14,000 (1 micron), but for steel my gut tells me 5,000 to 8,000 would probably be sufficient.
One thing I missed thinking of last night - diamonds are not strictly necessary for regular steels. I've used them a lot in lapidary work, but I usually don't with steel. I did just buy a fancy plane blade from LV, so I may start using diamond for honing it - but I doubt I would need to go as fine as Jack's looking for.
Grit to micron
Re: Diamonds
Re: Diamonds
Actually I'm not that picky.I'm not looking for a perfect edge. I just want sharp. My reason for posting is the same reason I haven't used diamond. I don't know anything about it,but I'm starting to get it. Diamonds probably aren't necessary for my needs but they are another way to get there and I should learn how they work.
I ordered three grits of paste offered by Traditional Woodworker and will do some experimenting.---Jack
Re: Diamonds
My experience
See if you can find out what May May now does. I think it is extra fine fixed diamond plate followed by strop of some sort.
15 micron on cast iron is about equivalent to a fine fixed plate, but the refreshed loose diamond on cast iron will cut faster. You may be able to go from there to stropping. I have been experimenting with this procedure.
Much coarser than 30 micron gets hard to use on cast iron. I have not used a grit coarser than 15 micron in years. Finer than 1 micron is overkill.
I see many carvers in many places do nothing more than strop on leather charged with green grit once the carving gouge is initially prepared.
Are you using diamond on cast iron? If so do you know how to charge the plate?
Re: Diamonds
Re: My experience- request
Howard Pollack
Bill-
Will you outline the procedure for charging the plate? Thanks.
-Howard
Re: Diamonds
Re: My experience
I have no idea what I'm going to do. I have never worked with diamond before-hence this post. I know nothing yet. I just ordered some diamond paste and am going to figure something out from there.---Jack
Re: Diamonds
...also
I'm thinking about shaping pieces of wood for rubbing blocks and charging these with the paste. I'm sharpening all curved edges that I use in windsor chair making.---Jack
Re: Diamonds
I second this request.
Re: Diamonds
Re: ...also
William Duffield
Use the hardest, finest grain wood you have, for example lignum vitae, snakewood, boxwood. The diamond will embed too deeply in soft woods or open grain woods, leaving very little on the surface to do the actual cutting.
Re: Diamonds
Re: ...also
I have a couple pieces of lignum laying around. Leftovers from making a mallet.Perfect.---Jack
