New WoodChat!
Diamond hone
Diamond hone
Jack Guzman from Maine
Diamond hone
I'm looking for a fine diamond to deburr the inside of outcannel gouges when honing. I'm not interested in slipstones. I want a tapered rod that is thin enough to use on my 1/4" detail gouge. I bought one online but it turned out to be too coarse. Does anybody know what I am looking for? Where I can get it?---Jack
Re: Diamond hone
Re: Diamond hone
Chuck Bjorgen
Not diamond, Jack, but how about the Spyderco ceramic four stone set? I use these to tune the inside burrs on some turning gouges. Lots of sharpeners have switched over to the Spyderco stones for general sharpening too. Here's what I'm talking about:
Re: Diamond hone
Re: Diamond hone
david weaver
Just my opinion, I don't think I've seen a diamond product that holds up well in that scenario. I think if I wasn't looking for slips, I'd buy slips :b
An india slip and if I didn't want to spend the fairly stiff cost for a trans ark slip, look for a ceramic slip.
I think that a dowel with autosol might not be bad (it's pretty aggressive when it's fresh - 3 micron aluminum oxide).
I've been working the ones I can't seem to avoid using with an india and trans slip, though, after the considerable time it took with an abrasive cone to get them set up.
Is there any possibility that you could set a dremel tool in a vise and do most of your rough work with a diamond chainsaw burr?
Re: Diamond hone
Re: Diamond hone
Bruce, a MN Galoot
my recently deceased buddy who was an excellent carver used a dowel and very fine grade sandpaper, 1000 - 2000 grits. Follow that up with a strop and you should be set.
Re: Diamond hone
Re: Diamond hone *LINK*
John in NM
Most I've seen are 600 grit, which is probably coarser than what you want. I'll post a link just in case, but it's likely what you found already.
You could try making one - turn a cone from cherry or maple to suitable dimensions and apply a slurry of fine abrasive, then once it dries use it without lube of any kind. I made one of those using slurry from a waterstone once, worked great. Other options are valve lapping paste, or any other kind of metal lapping compound.
Honing cone
Re: Diamond hone
reply and thanks
I think maybe I'll look into a ceramic slip. It sounds like what I was looking
for doesn't exist. Thanks for the replies.---Jack
Re: Diamond hone
Re: Diamond hone
Jack, DMT make a diamond plate called the "wave". It is a tapered cone, coarse on one side and fine on the other. I have one (because it came recommended), but I find it frustrating to use, and prefer profiled wooden slips with diamond mesh (from Lee Valley) and/or finish with green compound. The Spyderco slips appeal to me (I use the stones for chisels and plane blades), but have not tried them.
Re: Diamond hone
Re: reply and thanks
Clifton C
Jack,
Not sure what "fine" is. DMT has a 600 grit four inch taper, 3/8 to 1/8 and Trend has one, also at 600 grit. I found them on Woodcrafts website but I'm sure you can find them elsewhere. For me, the ceramics give a more finished edge, and then compound on a dowel for the final touch.
c
Re: Diamond hone
The one I got tore up the edge I had put on it. I just want something to remove the burr. I'll try a ceramic slip and see if that does it.
Re: Diamond hone
Re: Diamond hone
Hank Knight
I have that set. Those ceramics do a great job as a finish stone on gouges, V tools and other such things. Easy to use, no mess and they seem to last forever without getting out of shape.
Re: Diamond hone
Re: Diamond hone
TomD
Why not just make a slip out of some material and some diamond paste. Cheaper, and bettercutting than any of the things mentioned, and better control over the shape.
Re: Diamond hone
Good info on Autosol being 3 micron.
Chuck Nickerson
Anything in the .5 micron range that applies easily like a paste?
Re: Diamond hone
Re: Good info on Autosol being 3 micron.
david weaver
There are razor pastes that are 0.3 or 0.5 micron (you can get either) chromium oxide - pure chromium oxide, as well as, of course, the diamond pastes.
I think that aluminum oxide is in all of the "microfine" sticks, because chromium oxide of 0.5 micron is a strong cutter, but not that fast due to the small particle size.
You can make your own pastes by buying 4 or so ounces of graded chromium oxide (only graded, ungraded can have bigger particles) pigment for about 10 bucks and mixing it with anything - even something like toothpaste. Or, you can mix it thickly with mineral oil or a mixture of mineral oil and beeswax that is mostly mineral oil.
I think autosol is quite good, though - it will go well beyond the graded 3 micron size in honing if you put it on something and let it break in and only refresh it with a little stuff at a time (I couldn't tell the difference between MDF and autosol that is broken in a little bit and MDF with green chrome pigment only on it).
I would personally prefer to use autosol over the smaller particles due to its ability to "Break in" and then be refreshed on whatever it's on by just adding a little bit of oil to keep it mobile instead of adding more abrasive.
FWIW, if I put autosol on MDF, I have to sharpen two or three chisels on it before it has that fineness. The first thing sharpened on it, it shows its teeth a little bit and about matches an 8k waterstone, as you'd expect.
Re: Diamond hone
drill press, aluminum rod and diamonds
Its not the best but if you charge an aluminum rod with diamond paste it does a good job of abrading concave surfaces. Works best if you can slow down the drill press speed.
Re: Diamond hone
Re: Diamond hone
JDK
Another option is to use dowels and 1000 and 2500 grit sandpaper, a solution Paul Sellers frequently employs to great effect. I've used this technique to sharpen molding plane irons and the results are spectacular.
Re: Diamond hone
Re: Diamond hone
TomD
I used scary sharp/sandpaper in my shop for years in winter since it is cold, and found it great, but diamond paste is cheaper, cleaner, and better. In my particular experience. Cleaner because with paper there is often fine dust in the air that I prefer not to breathe. Diamond stays put though some black stain might result. I can do all my sharpening with one grit in diamond, because my honing grit is fast cutting.
Re: Diamond hone
Re: Diamond hone
JDK
Just to clarify...I am referring only to using high-grit sandpaper (1500-2500) wrapped around appropriately sized dowels (or specialized forms) to do the final polishing on gouges and/or molding plane irons that have been ground and sharpened using "conventional" means, i.e., oil stones, water stones, or diamond plates.
I think it's debatable whether or not diamond pastes used as a substitute for the sandpaper is more economical for this purpose, but it is certainly far less messy.
