Bad word, Bad word!
Just lost concentration and cut a pin off from a drawer back.
Taking a break. I made pins a bit smaller than usual....so small I forgot it was there and it was "off with its head" with the coping saw.
Bad word, Bad word!
Re: Bad word, Bad word!
Hank Knight
Bummer! At least it was off the back and not the front. Could have been worse.
William Duffield
Easy enough to fix, but an annoyance: Cut a deep V into the drawer back, a bit larger than the pin, and glue in a wedge to fit. When the glue is dry, plane it flush inside and out, saw it to length and recut the pin.
I've repaired stuck bureau drawers that had all the pins pulled out of the drawer side by an aggressive attempt at drawer extraction. Wedge shaped Dutchmen look neater and are a bit stronger, but if it's not a valuable chest and if there are several tails to rebuild, I've cut slots a couple of inches deep with a straight router bit and glued in stub tenons that I later recut tails in to match the pins. Either "pins second"
or "tails second" works, depending on which needs to be rebuilt.
I had to try it.....
I had already started a replacement back when I saw your note. It hit me as something I just needed to try, and I did, and I will be using the repaired back, not its replacement. I am satisfied with "good enough" for the occasion. It's a drawer back for a granddaughter chest of drawers. I suspect if someone ever discovers it years hence they will say, "now that's clever". And if they are a woodworker they will speculate, why was this repair necessary.
I have friends that strive for perfection in their pieces. I would find that philosophy too stressful.
The drawer goes in this cabinet....
Re: I had to try it.....
Brian Holcombe
Nice work Bill!
William Duffield
I was amazed when the guy I was working for showed me how to do it.
If you trust your glue, you can save the effort to do the baseline cut by angling the wedge the other way (wide at the end, tapering to almost nothing at the bottom).
details?
I cut the angled insert piece on the table saw, then scribed it's outline on the drawer back, wasted out most of the wood with the band saw, then chiseled to the scribe line.
Do you recall how you were shown? I like the idea of the insert tapering in to near nothing but how was the insert cut, and its destination cut?
That is a real handy fix...
John in NM
Got to file that one away for later!
Re: details?
William Duffield
There are multiple ways to skin this cat. As I noted, we usually used a straight cutting bit in a router, with the T-square fence that would be used for cutting a dado or sliding dovetail (but clamped to the end of the drawer instead of to the side of a carcass). Then we would cut the patch to thickness with the table saw. But that's a lot of setup for one tail or one pin.
If neatness counts, use your dovetail marker to mark the edges of the V in the drawer component. Or not. With the board clamped on end, saw out the V-shaped slot. Trim it sooth with a chisel. Scribe the patch (same thickness as the drawer component, or a little thicker) to the slot, saw it to the lines, and smooth with a block plane. Glue it in place. While the glue is drying, hold it in place with a clamp end to end on the drawer side, or just with a piece of blue tape. Plane the top and bottom of the patch flush with the drawer side faces using a block plane. Mark it as you marked the original. Cut and pare it the same way as you should have cut the original.
Mark, saw and pare it to length.
