How to remove veneer tape?
I have miles of it on this prone to split veneer. Never had to remove much in the past but in this case "best way"" becomes desirable.
Re: How to remove veneer tape?
Steve Elliott
My experience with veneering has been almost exclusively on a hot press using urea formaldehyde glues. With a water-resistant glue wetting the veneer surface and leaving it wet until the tape can be taken off with a putty knife is fairly quick and effective. On very porous wood species the stickum from the tape can still be in the wood and will cause the outline of the tape to show up during staining and finishing. Leaving the veneer surface wet for a little while and moving the water around until the stickum has been more evenly distributed will overcome this.
I know you use white or yellow glue for veneering so I'm not sure you will want to leave the veneer surface wet. A card scraper can be used to take the paper tape off but that's a bit labor intensive. In my experience just sanding the tape off with a random orbital sander can leave higher areas where the tape was. Most shops that do veneering use a widebelt sander to remove the tape.
Brian Holcombe
Bill I use masking tape (frog tape) and just peel it off at a 45 degree angle so that it doesn't pull fibers. I've done this on wild burls and VG all the same.
TomD
Nice thing about hammer veneering is there isn't any need for tape.
how thick is the veneer?
ian neuhaus
and how flat is the substrate?
conventionally, veneer tape is removed by wetting the tape to reactivate the glue and then peeling and scraping the tap off -- but this can be dicey with some veneers and bonding glues, meaning you need to resort to scraping the dry tape.
For a large flat area and lots of tape you might use a scraper plane, working at an angle to the tape.
The tape can also be removed by sanding, though you need to be very careful not to sand through very thin veneers
For future reference, where you anticipate using lots of veneer tape, wiping some of the glue off the tape before application helps ease its subsequent removal.
also for future reference,
3M used to make (probably still make) a wide transfer tape with a glue like that found on post-it notes. The tape is designed to hold adhesive letters and sign elements in position while they are positioned onto a substrate. I can see a use for this sort of material for holding veneer sheets together for cold pressed veneering.
disagree
ian neuhaus
in this instance Bill is using the veneer tape to hold a veneer prone to splitting together whilst it's applied to the substrate.
in the past I've used veneer tape to hold pieces of veneer together as a single sheet. In my case it was a sun-burst pattern
I'm not sure how you could hammer veneer either example without resorting to a using tape to hold the veneer together.
You'd loose one benefit of gum tape with that 3M
Dick Coers
and that is the gum tape shrinks slightly when it dries. So it pulls the seam ever so slightly tighter when it dries. All raw veneer needs to be sanded after gluing down, so I don't see anything wrong with sanding the tape. But I do use water and card scraper first.
Re: disagree
TomD
Fair point. I was just making a general comment about hammer veneering, I had no idea what project was being discussed. The only project that I have done that was anything like a fan, while hammer veneering, was a double book matched thing for a pedestal table a pal had back in the 80s. I don't remember any particular difficulties with getting the 4 pieces in place, but it might be different with a fan. We just drew the pattern on the substrate, veneered down one edge, trimmed the other side to the line, and then did the next piece, came out perfect.
