New WoodChat!
Hand Tool Training Project?
Christopher Fitch Memphis
The title of this post is a bit unusual.
There's an article from the Sept. 2004 Issue of Woodworking Magazine. It's just one page.
The article is titled: "Drawer Primer: Sliding-Lid Box"
http://www.shopwoodworking.com/digital-issue-woodworking-magazine-issue-2/?lid=MFpwbl012513
They made it mostly with power tools but I had two ideas:
- Make it only using hand tools
- Use Cedar Fence Pickets for the stock
So I went full hand-tool to try it out. Took a few evenings.
The second point adds some challenge since Cedar fence boards are rough and knotty so you have to pick your cuts. There are also two benefits in that the wood is cheap ($2.57 a picket for me) and marginally thicker than the final thickness of 1/2" so there is not much work to reach final thickness. Make a mistake... cut another piece out of a picket.
In addition, it's not quite wide enough for the bottom and top so you have to edge glue pieces to make them.
In my mind, all of this adds up to a simple but decent project for hand tool training for someone. Since it's cheap and small but covers alot of concepts, I think it's good for training:
- Selecting pieces carefully and cutting them
- Dimension and surface rough lumber
- Cut rabbets
- Cut grooves
- Edge glue small panels
- Minimal Carving/Chisel Use (for the recess)
- Gluing/nailing
- Finish Planing
- Finishing with Garnet Shellac
Here's what I made:
I'm not pleased with my rabbets, I could have done better on the lumber choice for the top, and the copper tacks probably should have been brass escutcheon pins but it still ended up decent.
I'm going to do some more...after all it's cheap!
Re: Hand Tool Training Project?
Neat!
I like your wood choice for the top.
Chuck Nickerson
Wood is (k)not plastic. Let its differences shine.
If you have the time, build one a month for a year. You'll like being able to track your skills improvement.
A different suggestion
Build something someone you like will find useful. The motivation of "customers" wanting something you make will zip you up the learning curve and keep the interest in woodworking alive for as long as you're alive (relating to the Ellis survey of the month).
I'm easily bored. Making 12 similar boxes would drive me from woodworking.
I'm assuming, perhaps incorrectly,
Chuck Nickerson
that a-box-a-month would represent a small percent of his woodworking time.
After Chris Schwarz re-popularized the 6-board chest I scaled it down to a 12" length and made 9 over the course of a year. The last few were each a three hour task and they all were donated to holiday toy drives.
