We value your privacy.
Is there something I can buy that will check the depth to see it is deep enough, and sides to see they are perpendicular, that will fit in small, say 1/4" mortises? A 4" square does nicely for larger mortises but it is too big for smaller mortises.
There is probably some machine shop tool for this task but I don't move in machine shop circles to know of it.
Bill, Starrett and others make a simple depth gauge with a narrow beam hat would work for you. Starretts are pricy, but there are, after all, Starretts. I have one that was my father's that I seldom use, but I have used it to measure mortise depths.
The best thing I have found, other than my favorite little 4" double square, for measuring depth - and other things - is an inexpensive fractional dial caliper I bought years ago from Highland Woodworking in Atlanta. The narrow beam that extends from the end when you open the caliper is intended to be used as a depth gauge; and, as I indicated, it is useful for a lot of other measurements, like setting fences and such. This little fractional caliper is one of my most used measuring instruments. I think I oaid about $35 for it 10 or 15 years ago.
I don't know what to suggest for measuring square.
Depth gauge, like that Starrett, works perfectly. It's also very handy for setting reveals and offsets and for setting marking gauges.
I picked up a very old depth gauge at a flea market in Australia for $10. Engraved with the name "Gary Cliff". On one side of the rule it is graduated in imperial 32's and 64ths. On the other side it is graduated in, if my memory is correct, decimal inches or maybe it's a strange scale that accounts for casting shrinkage. Kind of weird.
Like Hank, a 4" double square is also my favorite and I use it for checking both depth of mortise and sides perpendicular to face. If you are chopping the mortise (as opposed to drilling) the double square finds high spots better than a depth gauge.
Just cut an L-shaped piece out of some scrap wood, where one arm of the L is the depth that you need. You just need a piece that is thinner than your mortise. Should take all of two minutes to make.
If you do much work with slightly angled mortises, the 453 Diemaker's Square allows you to angle the rule slightly, or have it square. The 453C comes with the same skinny little rule: http://www.starrett.com/metrology/product-detail/453C.
Both of them are likely to cause your wallet to make little gasping noises if you buy at retail, but they show up on eBay for less.
I have the 453, and find it occasionally quite useful in its configuration as a square (as opposed to an angle measuring not-square); but it was an estate sale find at more of a bottom feeder price.
I use a little Chris Vesper or Starrett double square. These have blades that are 1/8" wide and enable one to check both the depth and squareness at the same time. The wide blades of other combination square may only check the depth.
I have a quality old fashioned caliper that has a thingy that sticks out its bottom when the jaws open. The bottom of the caliper sits flat on the top of the mortise and the registration of the part that sticks out will tell me if the sides are perpendicular to the face. No expenditure involved. thanks for the hint that led to a solution.
I don't do enough mortises to ever get proficient. Well in fact I do little enough of almost anything to get proficient. But with the aid of crutches I get by. By then end of 16 mortises I was getting better. These small ones go quickly.
The joinery in these bed side tables has become tedious. I have three drawers to make for another project and I may make them for a break in the tedium. I like making drawers.
I agree. Cut the tenons fat, level them with a router, and using the router, ease them in. If the mortise isn't quite deep enough, cut a bit off the tenon, or dig out more of the mortise.
