New WoodChat!
A big thank you to Knew Concepts
Simon St.Laurent - Dryden, NY
I bought one of their crazy coping saws a year ago. It cut wonderfully, but it was hard to get the blade in, the pins kept popping off the ends of the blades, and finally the lower cross pin came off.
I wrote them, and after a few rounds of back and forth on what could be causing this, they asked for a look at the screw to adjust the tension. It turned out to be the wrong screw, too short - someone must have grabbed one meant for a different kind of saw. (It was a little under 1 1/8", and should have been around 1 1/4".)
They promptly sent a new tension screw assembly, and everything works beautifully now.
Thanks,
Simon
