Wiley - I Finally Copied Your Jack Plane
david weaver
Wiley - if you recall the propotions of the mathieson Jack that you sent me. I took the opportunity to remake a jack for myself and copied the proportions of it (I had made a couple previously, but one is more of a closed-handle fore, and the second I made the handle too big for me and I'll have to find it a home).
It's funny, the 17" mathieson fore has almost identical proportions, except that it's much fatter and wider, and the handle is right on the back of the plane due to clearance issues with a closed handle.
At any rate, I used the handle off of your jack as the template and pretty much have a straight up copy for proportions.
https://www.youtube.com/watch?v=2yYnjUhVvzk
(plane in use is sometime just after 7 minutes - very comfortable proportions, a plane that will never cause pain in use. Brian Holcombe is already using a jack that has these same proportions and layout - I noticed when I made his and another one for Chris Griggs, that I was shipping off nicer planes than I was keeping. So, I guess I've copied it a couple of times before, but each time, I never got to keep it long enough to appreciate it).
Thanks again, by the way.
