New WoodChat!
Stanley 78 lever cap placement
I may not be fast, but at least I'm slow; I figure I'll be a beginner all my life.
I've had problems in the past with shavings bunching up in the throat of my Stanley 78, a plane I find very useful. Yesterday, I realized that the lever cap's chip diverter (see pic below) needs to be right against the side of the plane body in order to do its work of diverting chips; otherwise, it blocks them, causing clogs. This is particularly true when cutting rabbets (yes, yes, that's what it is, a rabbet plane; but it's often useful in other ways, too).
Experienced folks will say, "well, duh!" But I post this for new kids; that I get to look like an idiot by stating the obvious is just a side benefit.
It's a bit tricky, getting the cap oriented properly, keeping the iron so that it just barely pokes out beyond the body of the plane, and so on. But was it ever worth it.
You can see the chip diverter, below, in the mouth of the plane as the lever cap holds the iron down.
Re: Stanley 78 lever cap placement
Bruce, a MN Galoot
I never knew that, and chips bunching up is why I never used it much. Thanks for the insight.
Chuck Bjorgen
I just made that adjustment on my 78. The shavings on mine are coming out on the left side. Is that your experience too?
Yes, left side; the assumption is that you're using it right-handed at the bench, so the chips should come out the left and fall on the floor, from which location you can track them into the house, rather than on the bench, where they'll cover up your other tools.
I am comforted that I was not alone in being slow to realize this.
