We value your privacy.
The subject sort of says it all. Is there a proper way to cure bamboo? I made a camellia oil application dauber out of a short section, maybe 3" long with the node at the bottom and some heavy piano felt inside to hold the oil. The bamboo was locally grown (NJ) and was drying for about 2 years. I'm pretty sure the bamboo wasn't the fast, first year growth. The dauber is ~1-1/2" in diameter. After about 6 months, the dauber split on one side (including the node) and the oil began to leak out. Toshio Odate described such an oil dauber in one of his books, but did not talk about drying/curing the bamboo.
Anyone else try to make one of these? What am I doing wrong?
The large cane used for fishing rods typically will split as it dries, and then is further split to make rod sections. Its not really surprising that the stuff would do this given how fast it grows. There may be species less prone to splitting, but I wouldn't guess it has much to do with the drying method.
My bamboo was harvested for the exact same reason - use as trellis uprights for growing pole beans and cucumbers. I had cut the bamboo at least 2 years before and it was slowly drying in my protected garage during that time. If there were cracks in the material, I wouldn't have used it to make the oil dauber.
I'll try some of the heat and water soaking curing methods that Bob suggested.
I make the flyrods and the bamboo bows, even made mudguards for my touring bike. The stuff we get comes dried. If I had a cheap source to experiment with, I would consider putting it in a microwave. For one thing it works great for bowls, in theory it drives the water out from the center, which even if a myth works as though it is true. There is a movie on harvesting cane, and the methods are not particularly gentle and seem to involve fire.
Trout grass in one such film, but you can probably find something similar on youtube.
It may be that drying from the outside builds tension especially around the septum, which probably has a grain perpendicular to the rest of it. I'm thinking of an easy way you could dry the inside faster than the outside without much hassle.
Most modern refrigerators have their coils underneath these days, with a fan pulling air in from the front on one side, and blowing it out on the other side, usually the freezer side if they are side by side.
This air besides being warmer will be dryer than the ambient air in your home.
If you make a little plenum chamber to set on the floor in front of the fan draft, you could duct it down the inside to the bottom, drying the inside faster than the outside. This could be something as simple as a styrofoam drink cup, with a straw punched through the bottom, then down your bamboo. Don't set it too close, which might interfere with the fridge doing it's job, but -6'' out should be fine.
Now, this may check it faster than before, but it just might work. I suspect you may need to do it in short intervals, rather than just laying it down there overnight, but that might work, and certainly worth a try. What have you lost if it doesn't?
As far as something to prevent later splitting like you just experienced, you might try saturating the open end-grain and inside with thin CA glue, or CEPS.
I used the plenum method about 25 years ago trying to dry a deep hollow walnut vessel faster for a upcoming show. I think I only left it there for a couple of hours, but fortunately I inspected it, and found some checks forming on the inside, so dropped back to just taking it slowly by putting them in a paper bag, or cardboard box, so all the fiber has the same MC throughout the drying process, which means less tension within.
If you try any of this, and find it works, I'd like to hear back. Also, don't overlook the very bottom segments where the roots come out. when you sand them back there are usually a lot of cool natural characteristics down there.
