New WoodChat!
REAL MILK PAINT
Cleaning Up An Old Slick
John McGaw
I was just digging through my late step-dad's stuff and rediscovered an old slick. Some inspection shows that it is a 2" and was made by Greenlee. I'm pretty sure that it would be called a slick rather than a chisel, being heavy, thick, thicker at the socket end, and without the beveled edge of a firmer which seems to be more common from Greenlee. It has the original wood (ash?) handle with hoop.
Any advice on cleaning it up? I'm tempted to just use some abrasive since there probably isn't any antique value to it but I could give it a soak in rust remover if that seems advisable.
Re: Cleaning Up An Old Slick
I have limited knowledge of slicks, and others will be along to correct me.
Slicks are paring tools, and the handles were long enough to tuck into your armpit or against your shoulder. I don't think they were usually hooped.
I have been told that one characteristic of a slick is that the socket tilts up enough from the blade that the entire back of the blade can be set against a flat surface, with the socket and handle tilting up slightly from that surface; again, for its paring function. That's true of the one slick I own.
Heavy firmer chisels did come without side bevels, but I don't know what Greenlee's practice was; and, based on my finds in the wild, they certainly didn't sell in large numbers. They have limited benefit when you're trying to clean up a surface against an edge - such as the corner of a rabbet - because the side acts as a "fence" to keep the chisel on track.
As to the abrasive vs. rust remover: I use white vinegar for rust removal, and it's pretty darn quick in terms of labor time. Find a suitable container, put the chisel in it, cover it with vinegar, and ignore it for 24 hours. Then remove it, use a suitable brush to remove the rust, and immediately neutralize the vinegar with copious amounts of water, followed by copious treatment with WD-40 to neutralize the water. Let that sit for a while, then wipe off the WD-40 and proceed.
John McGaw
" socket tilts up enough from the blade that the entire back of the blade can be set against a flat surface"
If that is a working definition the I guess my slick is non-slick in that when sitting on a flat surface the back of the flat is lifted by at least 1/8". Guess I'll call it a really heavy 2" non-tapered firmer chisel. As soon as I can find a suitable container I'll try do do some sort of chemical treatment on it. I know that Greenlee always made good stuff (I still have some of my punches from my electronics-building days). Even if I never use it then some day someone may prize it highly.
Thanks.
Larry Barrett
Hi John
Does your chisel look like this:
This is a Greenlee 2" chisel. I bought it in the early 1970's when Woodcraft first opened. It was intended for timber framing, and is useful for that sort of thing.
Bill is correct about slicks - socket tilted up a bit to keep your knuckles safe when using. Clean yours up, sharpen it, and you will find a use.
Sometimes a tool is what you use it for
I've never found many uses for the slick I got from a friend's father, 40 years ago. Maybe if I'd built more boats (even one boat would have been more than the zero I've built, if you don't count kid toys).
But what you've got could work as a slick, maybe, if that's what you need. Or as a big framing chisel, if that's what you need.
William Duffield
I always put a hoop or striking ring on mine, because most of the old slick handles I've seen have been abused with a hammer at one time or another.
If it's a real slick, it should lie like this one, with plenty of room between your fingers and what you are paring.
If your wide paring chisel will lay flat without the handle, you can still use it as a slick, with a little fancy lathe work.
To lift the end of the paring chisel handle high enough that your fingers fit between it and the surface, you can turn the handle on two centers.
The red rectangle shows the turning blank. The blue lines show the two turning axes. The problem with this plan is that no matter which end you turn first, you don't have a place to put one of your lathe centers for the second turning. To get around this, turn the socket end first, leaving plenty of extra material at the socket end unturned, and just saw it off when you've finished turning the handle end. Also, note that the two turnings are concentric only at the point where the blue lines cross, and only if they are both in the same plane. Turn half of the cove with the socket end, and the other half of the cove with the handle end.
William Duffield
One other point: A slick's edge is typically ground with a slight camber, like a jack plane blade, but not as pronounced as a scrub plane blade.
John McGaw
Mine looks like this right now. I can't really tell if it matches your picture or not although mine is clearly the more rusty of the two.
