Shellac is magic - long
Bruce Mack
Currently I make small boxes and spoons for friends. Having observed that 2X lumber from the home stores often has a high moisture content and warps/cups after resawing at home, I began to use suitably cupped pieces from 2 X 8 lumber as box sides. The resawn boards are run through a thickness planer (sometimes over a jointer too) before the warping occurs. As the box sides are usually 12-16" long I often get a few nice pieces with mostly cup and little associated twist. These pieces can be mitered on the table saw. The glue up can be done without keys, with the help of a bottom set into narrow slots to square up the piece during clamping. After cosmetic planing the joints look good. This effort is made worthwhile by the curvature of the sides and ends, noticeable but not appearing contrived. I think the same effect could be achieved by resawing hardwood with a high moisture content, but with expensive waste not incurred using structural pine.
I’m left with pine sides with no figure to speak of. Shellac gives a wonderful luminescence to pine. Out of the Zinsser can it is a subtle amber. I thin it 1:2 with alcohol and add pinches of brown, yellow, and red powdered aniline dye until test pieces have a deep amber color I like. After 8-10 brush coats with fine steel wool rub-out, the box resonates. The coating is tough enough for its purpose, but can be further protected with a coat of Tru-Oil, a gunstock finish that can be applied with a finger tip. The excessive sheen from the Tru-Oil can be muted by a rubbing of rottenstone in mineral oil, followed by paste wax.
With my last box, I used this mix with a final 2 additional pinches of red to finish the carved walnut top. The dull brown became ruddy and rich.
For a retiree with love of woodworking and time enough to dabble in alchemy, shellac is perfect for enhancing small works. Your craftsmanship is enhanced by multiples. Think about purchasing a new car and receiving it before it hit the paint shop…..
[/URL]
[/URL]
[/URL]
[/URL]
