New WoodChat!
Try Plane in Benefit Auctions for Stephen..
david weaver
...the auction closes Sunday March 6 at 4 pm, EST.
Re: Try Plane in Benefit Auctions for Stephen..
Brian Holcombe
Nice work David! Your lines are super crisp. Have you gotten a chance to try it out, even without the handle?
david weaver
Thanks, Brian. I've worked it across a couple of edges and it's close to tuned. It needs just a little bit more tuning, which will be a lot easier to assess with a handle on it.
It's pretty easy to drop a plane when it doesn't have a handle and you're testing the corners (which is always where I need to do a little bit of additional tuning).
Brian Holcombe
Whoever bids and receives it will be in luck, your planes are the only planes that I did not have to mess with at all, just put them right to the wood.
The Kanna was easily a full days work, and all of my LN planes have been some effort.
Re: Immediate Fitness for Use
david weaver
If I had the same iron and same cap iron every time and they were the same shape, I might be able to make a plane without testing it first.
All of my iron sets are different, though, and the caps all work with the wear differently because they're not all the same shape. There's just no way to leave them like the japanese planes (which also have their own issues with the double iron if it's used, even though they have a very short wear. They're often set up so that it needs to be cleared some to use the cap).
I understand larry's planes all come ready to use, too. It's hard to feel sure they're fitted out unless they're put in a working state and tested.
Or in short, mine will always be set up and going to make sure that they don't get injured by bad setup practice before they're used.
That'd be a good pitch if I was selling them, though!!
The reality with them is that at some point, the wedge will get tight, and a user will have to be skilled enough to know how to make room on the cheeks or by trimming a wedge a little bit, so as with japanese planes, the tradeoff for having no rust is some future fettle.
Brian Holcombe
Absolutely, it mitigates the possibility of user error in setup. For instance, I know with relative certainty that Kanna number 4 or 5 will be better setup than my current one and faster, but eliminating most of that is certainly a benefit for the newer user.
TomD
It may not be cosmetically perfect, according to you, but it will do till it shows up. Very nice!
david weaver
Thanks, tom. You can see where perfection ends when you look at stuff like the termination of the bevel on the front left of the plane. Somehow, I lost focus for a second and overcut it at the bottom.
Someone who made more planes would make that cut more reflexively and "perfection" in that sense would be habit.
I like warren's terms for a standard of making things when he referenced an early make - that it was not perfect, but "handsome" and handsome is what I'm shooting for. Functional perfection is a little easier once the items that determine it are known.
