Re: Japanese Toolbox Build
TomD
I may be using the wrong term. I use a pretty aggressive blade. If one mounts the blade backwards so the teeth face the frame, and flare it out 45 degrees, then one can work it into a dovetail or whatever backwards and saw away. The result is that as long as your frame is about 60 percent the depth of the dovetail or tenon, you could saw a board 40 feet wide, no throat limit. Using a really fine blade would get old fast.
To flare the blade, you need two pliers, say, and to make a real bend with the pliers close together. This probably needs its own thread and pictures. Oops.
Basically we can probably all imagine cutting along the dovetails, or tenons, with the blade 90 degrees to the frame. Only problem is that if the blade is a tight fit, at some point you can't get it in there, this allows one to work a fat blade in a thing kerf, and yet have no limits to the geometry.
