New WoodChat!
Four down, four to go.
Just a quick update on the Lingerie Chest.
Four drawers done. They take 3 full days each to build (1 1/2 weekends). This includes thicknessing/sawing/shaping all the parts, dovetailing, and fitting.
The gaps between the drawers will be sorted out once all are done. There will be 1/16" between the drawers.
And the obligatory dovetail shot :)
The dovetails increase progressively, as with the size of the drawers.
Next post will be after all the drawers are done.
Re: Four down, four to go.
Brian Holcombe
Looking great Derek.
I'm wondering if you have made any headway as far as the handles go? Always seems the most difficult area of design for me, personally.
Cheers
Brian
Yes, I have designed handles that I believe will be sympathetic with the drawer shape. The issue at present is deciding on the material to build them from. Should they be Jarrah, to blend in with the drawers and not detract? Or should that be ebonised, to create some contrast.
I have just come across a set that is very similar at Lee valley, but in bronze (David Yoho has them on his cabinet on the main forum). Unfortunately, they are larger than I want (both longer and wider). Rats. That would have been an easy way out.
