New WoodChat!
More on work holding
Following on from Bill's earlier example, I was shaping a bow drawer front, and it occurred to me to take a few photos of the method I used to hold a tapered board.
Planing across the board to reduce tearout. The board tapers (as the cabinet tapers). I could just place a batton behind the board to prevent it slipping out the dogs. Instead I have used two Vee battens. These were described by Richard Maguire (The English Woodworker) and Chris Schwarz. Easy to make - just cut a vee (at approximately 45 degrees) at the end of a short batten. Use a hold down to fasten.
Incidentally, the blue tape on the board marks the line to which I am working. It really makes is so much easier to see what you are doing.
While we are at it, here is an one oldish tool that you must try - a scraper made from an old blade. This one is 3/16" thick. Just hollow grind square. This is sufficient to create a cutting edge that will make shavings like a plane. Great for shaping. Here it was used to take down the plane marks and even out the surface before smoothing with a spokeshave ...
Re: More on work holding
The steel vise replies
smoothing the outside of bow front drawer
smoothing the inside.
Re: The steel vise replies
Hi Bill
Touche! :)
I am sure others will chip in here with their thoughts ..
When shaping the face of the bow drawer fronts, I prefer to support the whole board. The board can flex in a vise, and I would be concerned that this leaves hollows after planing. What was your experience here?
In my case, I needed to plane across the grain as the wood is very interlocked and hard and brittle Jarrah.
Re: scraper
William Duffield
If you don't want to make one, Stewart-MacDonald sells scrapers on the same idea.
http://www.stewmac.com/Luthier_Tools/Types_of_Tools/Scrapers/StewMac_Ultimate_Scraper.html?utm_source=google&utm_medium=shopping&utm_campaign=2016-02-gp&gclid=Cj0KEQiA0Na1BRDlkqOcyczng5cBEiQAnEDa2CSM9UJ4YIa4sRMJytJEKA0QHB-AUG5i4aUQXcgP3A8aApTp8P8HAQ
As I reflected on the first picture....I don't know what I am planing in the first picture. It is bowed. It seems to be walnut and it was in the file for building a walnut bow front. It is some part of this chest of drawers but I am flummoxed as to what part.
The drawer substrate for this piece was poplar and it was thick and robust when the outside was planed (then sawed to thickness after the dovetails were cut). Flexing would not have been possible in this thick piece. In any case the saw teeth marks are depth gauges. When they are gone stop planing that part.
