Crisscross, Chain, or Parallel guide?
Tony
For the bottom of a leg vise, which would you use?
Tony
Re: Crisscross, Chain, or Parallel guide?
Jack Guzman from Maine
Both leg vises in my shop are antiques and they both use a piece of wood about 1 1/2" square by 12" long that is attached to the bottom of the jaw and slides through a mortise on the bottom of the leg. The piece has a series of holes drilled through it that take a peg to position the distance between the jaw and the leg. If this isn't clear I can post a picture.I like this design because of it's simplicity. When I built a new leg vise for a bench I built I used this design. It works fine.---Jack
Jason in OC
I used a crisscross. It's about the same amount of work to install as a parallel guide and you never have to mess with adjusting the parallel guide's pin.
Some people think adjusting the pin is a huge pain, and others think it is no big deal. A variation on the parallel guide is to use a wood screw with a stop nut that you turn with your foot. An example can be seen in the last picture of this post:
http://www.popularwoodworking.com/workbenches/schwarz-workbenches/erik-mortensens-awesome-english-workbench
david weaver
Whatever you'd like to do. If you put a pinboard through the leg instead of using a crisscross, my personal preference is to make the bottom stretcher low and put the board above the stretcher rather than all the way down at the floor. You don't have to bend down as far (and you get more room between the shelf and the bench to keep things away from the bottom of holdfasts. I haven't seen strength to be an issue.
I got several comments when I made the vise that it wouldn't be strong enough with the board above the bottom stretcher (not enough leverage or something), but that turns out not to be even close to true.
I can't speak to a crisscross, it's out of my budget.
AZ in Colorado Springs
I have a parallel guide, 1/2" x 3" or so. It's located at the bottom of the leg (I think cutting the mortise for a guide positioned as David described would be a lot of tedious work -- my bench legs are 5" x 5'). I use mostly 4/4 stock so I don't have to move the pin very often.
david weaver
It was a little bit of work if I recall, but I think I drilled the mortise out with a holeshooter and it was pretty quick and then malleted the rest out. My legs were also thick, they're 3 laminated 8/4 ash boards with as little taken off as possible, so about 5 1/2" x 5 1/2"
Admittedly, I didn't have much for plans (or anything at all other than a general idea), but I built the bench in a hurry and didn't get too neat with anything.
Just about anything will work, I guess that's the lesson.
