Bench: Liquid hide glue for laminating?
Tony
I've been using liquid Hide glue for everything. As I look at laminating boards for a bench, I wonder if it is the best choice for that or should I look at something else?
Tony
Re: Bench: Liquid hide glue for laminating?
TomD
I often have a gallon of Titebond 1 because it is the best general purpose glue yellow/white, I get one at the begining of the year and toss it at the kids as craft glue when there is any left over, though it last a lot longer than a year, but I keep it fresh for lutherie. A good grade of regular white glue if you can find a recipee that hasn't been messed with, is a good choice and has more open time. Epoxy is great, but up here I reserve it for high end uses, with the dollar so low. I think one can use anything, I don't really see a reason to use liquid hide, it is expensive around here, and not that great compared to real hide. And real hide I would not want to use on a large project. Liquid hide is used in a lot of furniture factories, though I think they have a different process than most home builders.
I am talking here about lateral butt joints, in the joinery for a bench, there are good reasons to use a variety of glues, but for tops I don't bother.
don stephan
Hoo boy, the last poor soul who asked about hide glue got thrashed for days on end.
david weaver
I would just use titebond or something similar unless your shop is really warm. You'll have a large glue up and if the surfaces aren't warm with liquid hide, you can end up with a "cold weld" joint where the glue doesn't fully harden.
When I made my bench, I bought a gallon of TBII or TBIII, I can't remember which, and used it.
If it ever fails..well, I doubt I'll be mobile enough to woodwork by the time it would.
Bruce, a MN Galoot
I glued my bench top together with titebond, don't know which one, but 30 years ago I think there was only one. Anyway, it has held together just fine, face-glued 2X4's. Get yourself a narrow roller and roll out the stuff if you're worried about open time.
Tony
I have one of those Mitsubishi ductless units to heat/cool my shop. I can run up the heat when I need to.
david weaver
Something close to 100 is probably a good temperature. At least 80 or so to get a good hard glue joint.
You could also preheat the material if you can confine it, and that would probably help.
Warren and others who have shops set up to glue with hide glue all the time would have better suggestions. I've used a space heater in a small area, and I've used old incandescent lamps in confined areas (a trick relatives of mine use to heat a dog house in the winter - or used to when people kept dogs in dog houses).
Jack Guzman from Maine
I also use liquid hide glue for almost everything. When I built my bench with glued up maple strips I used yellow glue. I got a cheap 3" roller and pan kit from the hardware store to apply it. ---Jack
GolfSteve in Calgary
Laminating boards for a bench: Titebond original would be my first choice.
However I would have no worries about using Franklin liquid hide glue either; it offers longer open time and dries hard. I would leave the lamination in clamps longer than Titebond. I don't like Old Brown Glue because it is too viscous at room temperature. If I have to heat the glue I might as well use hot hide glue.
Titebond I would leave in clamps a couple of hours. Liquid hide glue at least 12 hours. Fish glue at least 24 hours. You're putting a lot of moisture into the glue joint and cure times, especially for Fish Glue, are very long.
I've had a couple of laminations (using Titebond) peel apart as I removed the clamps because I did not allow enough drying/cure time. This seems especially important when laminating multiple layers of thin stock - the amount of moisture in the package is very high.
AZ in Colorado Springs
I built my roubo style bench in 2014. I used titebond I extend. Even in Colorado in August (implying humidity under 20%) i had plenty of open time. Seven feet long, 3-1/2" thick, so lots of area to cover on each lamination. I use a plastic putty knife with an irregular edge made with a triangular file, as a glue spreader.
In fact, now I use titebond extend all the time.
