Re: Workbenches to buy
TomD
Other people telling you that they like a given bench is pretty useless, other than maybe for quality control. Two reasons. One is the rampant faddism of the whole bench thing. The other is the obvious individuality of needs, from available space, to the way one works. Benches basically come down to the base, the top, and the vises (if any). Evaluating the function of these elements is not all that difficult. In some cases it probably doesn't mater that much what you get. There are a variety of bases. Probably the least efficient, the Roubo, has been massively popular for quite a while indicating that the actual choice is not all that important. With bases, they all work so long as they are rigid. I have several benches in the shop and I never have got around to fastening the tops to the bases, further evidence that the whole this is more forgiving than one might think.
I was coming off a plane crash back 20 years ago and had to adapt a bench project to get it done. I substituted a base using LV legs, which I did not find stiff enough, but certainly they were OK, that reduced the work I had to do, and when I felt better I built a regular sled base. I made the top really big, but basically it was laminated out of a few pieces. Clamped up on top of some saw horses and then slid onto the bench so I never really had to do much lifting. I also made it in two pieces with a crack down the middle. Occasionally something falls down the crack, but overall the utility for tool holding and workpiece holding is still . I am not sure the heavy lifting quotient (or whatever we are controlling for here) is really that much worse than assembling a bench that arrives in pieces.
The Adjusta bench seems like a good idea. Never seen one to be sure it is dead nuts solid. I think one also has to physically lift the bench top to raise it, an end at a time. Depending on one's limitations, that might not suit. I would check out a motorcycle lift, to see if it was solid and level, they can be had cheaply during sales at places like HF.
I have a take down bench that I made up using a temporary plywood hollow beam as a top. I was going to switch out the plywood top when I got the right piece of wood. I eventually found my piece of wood, but the plywood top is so good that I did not replace it. Plywood for bench components is a really great option and will make construction a relatively easy thing.
My favorite five features on a bench are min 8 foot overall length; wedged trestle bases, look nice, and rock solid, easy to demount; hardware bonding, neater, cheaper, better looking; Square dog holes; mechanical vises. If I could have something I don't have it would be adjustable height, though I have multiple bench heights.
