New WoodChat!
Stanley scraper plane blade
Richard L. Snyder Sr.
Recently bought a Stanley #12 scraper plane along with a new HOCK Blade. I've seen two video's regarding the plane and sharpening (Lee Valley and Lie Neilson),both of which were not that clear. For those who have one, what is your method? (free hand,jig etc.)
Thanks, Rick
Re: Stanley scraper plane blade
David Charlesworth
Rick,
This is covered in detail on my 6th DVD "Five Topics".
The subject is a bit long to write here!
Available from me or L-N.
Best wishes,
David Charlesworth
Hi Rick
I have the big brother, Stanley #112. Mine has a LN blade (from the days when LN made a blade specifically for the Stanley - slightly thinner than the LN version, but thicker than the original Stanley. I imagine the Hock is very similar to the one I have).
It has been some years since I used it. I prefer cabinet (card) scrapers.
I seem to recall that the blade originally came with a 60-degree bevel. At any rate, I reground it to 45 degrees in line with the blade in my Stanley #80 scraper plane. I then began grinding the primary bevel at 30 degrees as this made it easier to turn a hook. Some use the plane without a hook, but I found that it produced better shavings with one.
The blade angle is adjustable in the #112 and #12. To set the blade angle, first use it freehand. Note the angle where it works best, and then try this out.
William Duffield
L-N #112 blades are now also beveled at 45°. I think they changed when they realized that users would find it difficult to sharpen a 60° bevel in most sharpening jigs. A 60° bevel provides a more durable edge, but if you are going to turn a hook, it's not going to make much difference.
David Charlesworth
Think of the blade as a plane blade with steeper sharpening and a very slight camber.
I grind at about 35 degrees, get a wire edge at 43 degrees on coarse stone, then polish at 45 degrees.
All honing using Eclipse type honing guide.
Back prepared like plane blade, I use ruler trick on 8,000 stone to finish.
Razor sharp, hardly use any force used when turning hook and pay attention to angle. 75 deg.
Setting angle, same as Stanley 80. Light shavings. Bliss !!
David Charlesworth
