We value your privacy.
I'd like to make an awl for a friend that does metal work, blacksmithing, etc. Any good sources/ideas/suggestions for the scribing part? The wood I can handle. I've seen some stuff out there, but most of it is short and meant to be installed in a chuck type pencil. Even considered buying something and just replacing the handle.
For my wood awls, I just used untreated steel. The tips stay sharp for a very long time. Not sure that would work for metal though!
You could get some O1 from McMaster Carr, maybe 3/16 diameter, and harden it yourself. It's easy to do with a propane torch on a small piece, then you can draw the temper a bit in the kitchen oven (450 or so, I would have to look it up).
Only trouble is you'll have to buy 3' of it, but it ought to run around $10 so you could make lots of awls.
Depending on what it's being used on, I've taken an old nail set and ground the tip to a point. It has been hard enough to make a dent in annealed steel.
Scratch awls for metal are called "scribers." Googling "replacement metal scriber point" offered lots of possibilities: Amazon, MSC (industrial supply house), etc. Some are carbide inserts on steel shafts, some just highly tempered steel shafts.
They're not long, 2" - 3-1/2" it seems; but the factory scribers I've got aren't large tools.
You might get a little extra length of shaft if you get the General Tools #380A scriber, which has shafts that screw into a handle. If it's like the similar scriber I've got, it'll have more length to the shaft. Later edit: the straight shaft on my Craftsman example is pretty short, but the right angle shaft is 6-1/2" long. If you're after a long shaft, and the General Tools version is similar, you maybe could grind off the right angle point, chuck the shaft in a drill motor, and shape it on a stone or, perhaps better, wet-and-dry sandpaper on a suitable (firm) substrate), lubed with something to keep it cool.
If he's doing blacksmithing and working with hot metal, you might want to look at woods that char less easily. It's possible the link below will help a little; I couldn't find much else in a quick look at the internet.
If you're wanting to make a scribe and make the point, go to a local hobby store and get some "music wire" in a suitable size. Form the point and heat treat like 1095 (a search will provide tutorials).
Be aware that any wood/handle material will soon become black in a blacksmith shop.
I would probably start with the O1, which can be found as drill rod in most hardware stores. Just heat till it is unmagnetic, then a little hotter, and plunge into bacon fat or 150 deg olive oil. The oil will flame particularly if you plunge it in and take it out while it is still hot enough to flash the vapour, so leather gloves and pliers are an idea.
Once you have hardened the tip you can draw it out, use as it, put in the over to cook at 450, etc....
Concrete nails are hardened and good for small tools, you just need to grind them without drawing the temper.
You can get hardened pins from industrial supplies.
Most metal being scribed is either dye chemed so you are really scratching the paint; or it is blackened through heat, and one is scribing the oxide; or it is anealed or semi hard. So while most scribes these days are carbide, at one time they were simply hardened like normal tools, and that hardness was adequate for all the above uses.
I just went out and tested a couple of my awls against a Starrett scriber, on some cast iron (out of sight area on a table saw). The Starrett scriber made a distinctly sharper, more visible scratch. This leads me to think that there is a tempering difference in the tools intended for metalwork. Or else the scriber is just super-sharp, which may also be true.
This gives me some ideas. I had seen the replacement tips for the Starrets. That might be an easy way to go. I have some material I bought from MSC or somebody like that to make my awl, but I can't recall what it is. I think I bought two pieces - maybe 01 and A? I'll have to check. Might be a good reason to learn how to heat treat. Never tried it. Dealt with it a LOT in my days of making engine parts...mostly it was a nightmare! Even at a commercial level, it is black magic. I've forgotten most of what I learned back then.
I started out thinking about making a palm type handle, but now I'm thiniking more along the lines of a pencil shape.
