Re: marking gauge
Hi John
I really like the wheel gauges for their thin lines. I prefer cutting gauges to pin gauges because the lines are clean and unidirectional (unlike the triangular indent of a knifed gauge) owing to the thin cutting wheel. They can do this both with the grain and across the grain, unlike a pin, which is best used with the grain.
The lines are "light" and the key factor here is that you must remember to deepen them progressively with a few extra strokes.
The alternative - which is a revelation once you start doing this - is laying down a layer of blue masking tape over important joinery on wood surfaces where lines are generally difficult to see, and scoring over this. One only requires a single stroke.
The resulting lines starkiy contrast with the background, making it so much easier to work accurately.
The dovetail is one example, but you can do this for tenons as well.
I am not trying to sell the blue tape, however, just trying to demonstrate that the clean, fine lines of a wheel gauge are so good that initial impressions when contrasted with one's experience of other gauges is an anticlimax. You just need to know what to do with the fine line, whether to deepen it or to use it as is.
Regards from London
