New WoodChat!
I did a woops
I did a woops
Jack Guzman from Maine
I did a woops
I build windsor chairs. I've been learning how for a few years now. I'm putting together a continuous arm rockler using some plans that Curtis Buchanan made up.I got my legs and stretchers done and dried the parts that needed drying. I shaped the front of the seat and carved the seat bowl. I had left excess wood on the back to give me a clamping surface.
Yesterday morning I decided it was time to assemble the legs and stretchers to the seat. I glued the stretchers to the legs and then glued these assemblies into the seat blank. I drove wedges into the leg tenons and I was done. I was content. It all came together without a hitch. Everything fit right and all was in proper proportions.
I was standing back admiring the new seat and I noticed my woops.
The excess wood at the back of the seat was still attached. Usually I cut this off with a bandsaw and then clamp the seat blank into my double screw vise and shape the back with a drawknife before assembling the seat. There was no way I was disassembling the leg system at this point so I just walked out of the shop and left it for a new day.
This morning I cut off the excess with a jigsaw and alternating between my regular drawknife and my 4" Jennings carvers drawknife I managed to carve around the legs sufficiently to finish the job. All is well again and I won't do that again.---Jack
Re: I did a woops
Painful, or at least hassly, lesson
Glad you were able to salvage it. Thinking about how much you learned may be cold comfort right now.
A picture would be a nice touch. I bet we'd be unable to tell you had to fix it after the fact.
Re: I did a woops
Unfortunately I didn't think of taking a picture of it before I fixed it and you really can't tell there was a problem.However,I do have a picture as it looks now. The piece I cut off the back is in the picture laying across the rockers. ---Jack
Re: I did a woops
Re: picture
Bruce, a MN Galoot
Holy mackerel, Jack! I thought you were talking about a little horn sticking out the back, not the entire width. I guess I would have quit for the day, too. Very nice recovery!
Re: I did a woops
Re: picture
William Duffield
I had the same first impression Bruce had. Wow, that's a lot of material to remove with the legs in the way. I think I would have been so upset that I would have backed off and stared at it for a couple of months before getting back to fix it.
Re: I did a woops
BTW, Jack
Bruce, a MN Galoot
Nice crisp turnings you've got there!
Re: I did a woops
Re: BTW, Jack
Thanks. I've been working at it. I am inspired by watching Curtis Buchanan and his student Elia Bizzari. They are both skilled at skew work. It is by far the hardest skill I have ever tried to master.---Jack
Re: I did a woops
That's how I get 7 partial projects in my shop.
Re: I did a woops
Re: BTW, Jack
Bruce, a MN Galoot
Some years ago I built two beds, each having a curved headboard with 17 spindles in it. The round spindles tapered from 1/2" to 1" with 1/2" tenons on either end, and a bulge (don't know what else to call it) someplace toward the bottom. Since the headboard was curved, the spindles were also different lengths. Each set of those spindles took me over 6 hours. I told a friend about my efforts. He's an extremely proficient turner and told me that with a sharp skew he could have done all 17 of them in less than 45 minutes. He and his wife built a cottage on their land and financed it by selling custom-made knitting needles that he turned.
I should probably learn to use a skew. It's not easy, so I applaud your efforts.
Re: I did a woops
Re: BTW, Jack
William Duffield
You don't hve to learn all of them at the same time. I've learned some of them, but not all. The ones you do learn will save you time and result in better turnings. I've watched Elia Bizzarri at aa WIA, and was fascinted by everything he turned. He offers instruction, which I wish I had time to take.
http://handtoolwoodworking.com
