New WoodChat!
New project
New project
New project
Larry Barrett
The oak was about 50 years old and 10 yards into the forest from the edge of the field when we bought the property. We had to clear a few trees for the house, which opened the tree to the sun. In the next 30 years it nearly doubled in size. The upper branches grew toward the light and further and further over the house.
If the tree came down in a storm it would take the house with it, so we reluctantly decided it must come down. It took a month to clear the debris and split and stack firewood from the branches. About 3 weeks ago I was able to open up one of the 4' sections from the main trunk. It was over 24" in diameter and took awhile.
After more splitting and riving, chair parts were roughed out with hewing hatchet and drawknife. Back posts were steamed and bent on a form.
A new chair emerged a couple of weeks later. I have made this chair several times before, but not for a few years. Felt good to get back to it.
Re: New project
Really nice!  Thanks for showing us!
I'm intrigued by the step from round to flat on the back legs, right above the seat. And do you round off those square shapes at the front corners after the chair is assembled; and, if so, what benefit does it give you to leave them square until that stage?
Re: New project
Re: Really nice!  Thanks for showing us!
Larry Barrett
Bill
The back posts are first squared as they come off the log, then into octagons. The flat part above the seat is also done at this time, before the back post is steamed and bent on a form. Hope you can see this in pic.
After it dries and is off the form the slat mortises are chopped and the post rounded.
The rectangular blocks that you see at each end of the front rung are actually part of the front rung. They provide a home for the front leg tenon and the side rung tenon. The seat material, once in place, is even with the top of the rectangles; when sitting, you do not notice it at all. Hope you can see this in this pic. On the left is the same chair with the seat warp in place and the side rung still uncovered. On the right is a similar chair (in walnut) with a finished seat.
Re: New project
Oh Yeah 👍
Re: New project
Thanks for the explanation
Re: New project
Re: Thanks for the explanation
TomD
Great looking project, and some beautiful wood.
On the squares, some chair makers use that approach to make the front rail flat so that there is less pressure on the inside of the leg. In that case there is a step down form the size of the squares, but the material under the seating is squared (usually rectangular) in section. You can simply carve an airfoil into the rung, but I prefer the method shown here, but with the flatter section, looks neat, and more solid.
Antique:
Boggs:
Re: New project
Re: New project
Anj12305
"After more splitting and riving, chair parts were roughed out with hewing hatchet and drawknife."
There's an understatement. Each round was - what? - 30 inches in diameter?
Re: New project
Re: New project
Larry Barrett
Yes, a bit of an understatement. The tree was 36" in diameter about 3 ft off the ground. I sawed the trunk (well, I did not do it, the pros who took the tree down did it for me) into 3 4 foor sections, and the section I split first was the top section - a little less than 30" in diameter. There are a lot of chairs in that one section if I get that far.
