We value your privacy.
I know that many of us were pressed into duty helping Santa. Hopefully that work is done. So, what is next up in the shop?
For me, who recently moved into a 9 ft by 17 ft workspace, it involves tweaking how I originally arranged my shop. After working in it for a few months, I have discovered a couple of things that are not workable. I hope to be able to fix it in a week. Have to do a new arrangement for clamps. ( i actually have too many) a new storage cabinet for chisels, and a rack for mallets and hammers.
Then I get to make drawbore pins, a new cutting gage, and a krenov smoother. Oh, yes I have a wife and two grown daughters who keep dropping suggested projects. Better do some of them 😎
Once I finish my moms cabinet (very soon) I will be putting the friend/family/ect projects aside for a while and doing some architectural cabinet/door work around the house....hopefully.
Planning some vanities, medicine cabinets, bed side tables, a door, saw horses and probably a bunch of other stuff will pop up.
And paint....lots and lots of paint. Which would be a quick project if I did not feel the need to smooth every wall and fix every nail pop in the house prior to painting (OCD). And my wife wonders why I want to rip down a few areas of drywall and put up walnut paneling.
I've got four, 5' long by 14" diameter walnut logs that need to be cut up into slabs/planks. I am at a bit of a loss as to how to do this as this is a bit larger than what is reasonable for pushing through a 17" band saw. Doable I think, but I'm asking for trouble. Some engineering is called for.
I've also got to put a finish on a lectern that I built to go on my credenza at work to give me a place to read patents while standing. I have a tendency walk about the building with printouts as I can only sit still for so long.
Your logs sound as though they would be pretty heavy to manhandle through a shop bandsaw.
I know there are some local owners of the Wood-Mizer type bandsaw sawmill units in the Twin Cities area. You might ask in the web site for the Minnsota Woodworkers Guild. Just ask in the classifieds section.
they were! I think I got some good stuff from the process, but I also think I burned out my bandsaw motor. It stopped producing torque though it still runs.
I also made one hell of a mess in the garage. This alone means I may not do this again any time soon.
I had something like that once. I would turn the switch on, and nothing happened. Went out and bought a leeson motor, and as I was getting ready switch it in, I noticed the original motor was spinning inside the pulley. Without moving the pulley the motor, nor anything else, made a sound. I re-installed the spline and tightened down the set screw and my Dad still has it about 30 years later. LV took back the Leeson motor.
I have a device called the AccuRight Log Mill, from the Carter bandsaw folks for processing shorter logs. It has a limit of only 21 inch logs though. It works pretty well with the short stuff.
drinking coffee in an effort to get motivated to find the problem. I had been wondering about the key as when I turned the saw off last night, I recall that the blade stopped and yet I heard rotation noises. $1 fixes are my kind of problem.
I find that as my toys get more interesting (and more complex) the fun of fixing stuff has begun to fade. I have to see about doing a factory reset on an older AirPort Express this morning to ensure that our kitchen speakers can play music/radio. I've become seriously uninterested in some of these things lately.
a side table to match a Morris chair. Several pieces for each project have already been cut. It's just time to get them done. With any luck all three will be done by the end of January 18th.
I know I shouldn't have three major projects rolling at once. Fewer consecutive projects will probably be my 2016 shop resolution.
