Another awl
Hi Bob
I used one with a similar handle for many years. Then a year ago I built a couple that I considered to be more ergonomic for my hand and the way I use them (personal preferences). The idea was based on a birdcage awl needing to be twisted and pushed down simultaneously. This differs from a scratch awl, which I hold like a pencil.
I have made these in different steels. HSS is easiest to purchase. The one below is 1/4" square carbide, which came from Czech Edge (as a kit for the blade). The bevel has been reduced to 25 degrees (it comes with one at 30 degrees).
There was some discussion on Old Tools about the benefits of a three-sided blade, as you have made. It makes sense insofar as creating a coarser cut than the four-edged blade. Is that the reason behind your three-sides, or was there another consideration?
