New WoodChat!
Bridle jointing the demilune
An article in FWW and an episode of Rough Cut describe making a demilune and in both cases the hard part is glossed over, namely laying out and making the bridle joint for the two front legs. No doubt someone in 1740 figured out the best way to proceed but I haven't found their notes. So I forged on with inspiration driven by necessity. It may not be the best way, but it worked.
PIC 1
Picture 1 shows the result. what follows shows the process.
PIC 2
Step 1 is to locate the boundaries of the joint the width of the leg. I realized that the leg falls on the radius of a circle. So I located the diameter of this circle and the center of this diameter (and center of the circle) on a stick spanning across the back of the demilune arc. I cut a second stick the width of the legs and drove a pin through its center. I located the pin in the center of the circle and spanned to the radius of the circle (the table skirt). Locating the leg is then a simple matter of making scribe lines on the skirt as determined by the sides of the stick (which is exactly the width of the leg) which has become the radius of the circle.
PIC 3
The scribe lines are extended down the face of the skirt. Saw kerfs are made along these lines with the depth equal to the depth of the bridle joint.
PIC 4
Additional saw kerfs are made across the waste to exactly the depth of the bridle joint. The waste between the kerfs is bashed out. The remainder of the waste is pared using the saw kerfs as depth gauges for the paring. This last part took a while to get a good fit to the leg.
Re: Bridle jointing the demilune
Brian Holcombe
Nice work Bill. Long bridles are always tougher to make than they appear. Will these terminate in the top as well? I notice they do this on long bridles in Chinese furniture, but I've not taken notice to wether or not it is used in Western furniture.
Re: Bridle jointing - aka sweating bullets !!
Rum
Somewhat terrifying after how much you have in that, but nicely done. I'm afraid I've have walked around and stared at it for several months before getting up the courage.
Hi Bill
I guess that I tend not to overthink these matters. For example, the important measurement is the one closest to a feature, such as a drawer edge, since that may make it evident if a joint is out-of-position (if there are two for comparison).
I've built a few demilune tables. The main difference was that the surrounding face was built of laminated Jarrah strips, and therefore thinner than your solid wood version.
I also began with a centre line ...
.. then saw and chisel ...
Result ..
perceptive insight
"I'm afraid I've have walked around and stared at it for several months before getting up the courage"........in my case it was only a month. I felt bold :)
It was the most stressful part of this build. Curved stuff adds more complexity and risk and I haven't built much curved stuff to gain confidence. Today the table gets glued together and if all the legs more or less reach to floor I will be happy.
