New WoodChat!
Lingerie Chest- Designing the Drawers
This is the start of the second stage in this build. Now that the carcase and drawer blades/runners are completed, it is time to start on the drawers.
The drawers are complex as they call for compound angles and dovetails. The design may be improved, and I welcome comments about this and the methodology.
This chapter provides a pictorial on the design and construction I have come up with so far. Pine is used in this test case (where Jarrah fronts and Tasmanian Oak sides will be used in the final build). However, the construction is for real.
The link is here (too many photos to post on the forum): http://www.inthewoodshop.com/Furniture/DesigningTheDrawers.html
Re: Lingerie Chest- Designing the Drawers
Paul in NJ
Hi Derek,
Such fun! I think you are on the right track. When I did my bombe’ chest years ago I had a similar challenge. Like you, I chose to angle the drawer sides by beveling the top and bottom edges. The advantages are using thinner stock and having a lighter drawer. I did the same thing with the drawer fronts, they were beveled top and bottom so that they would match the angle when viewed from the side of the case. All the drawer fronts and dividers were shaped together so they flowed together nicely. I fitted the drawer fronts and backs to the case openings. The angle of the sides were picked off the tangent of the curves on the drawer front. I needed to add a rabbet to the inside of the drawers because the curve was so severe. You can see that in the first picture.
The thickness of the sides was just enough to sit proud of the front when the joint was completed. I scribed the profile of the drawer front and backs onto the edges of the sides, disassembled the drawers, and planed the sides down to the scribed marks. Afterwards it took minor adjustments to have the drawers fitted. I think it is important to note there are no “curved” dovetails. Everything was laid out to the tangent of the curves, look at my second picture.
Looking back, my only regrets are that I could have proportioned the dovetails better. Good luck and enjoy.
Regards,
Paul Dzioba
Many thanks for such detailed reply, Paul. It is great to hear from someone who has gone down a similar path. I do recall your bombe, and how well it turned out.
I am interested to know how you made the groove in the drawer front for the drawer bottom? Score and chisel? Power router?
Also for the sides? There, I will be using slips, and the angled sides require that there is a corresponding bevel on the inner face of the slip to be square.
Paul in NJ
Truth be told, I used a bearing guided bit in a router table. I used a chisel to make the grooves deeper. I had one breakout in a drawer front when I had an unexpected climb cut but I was able to glue in a patch that matched well. If I had to do over I would score with a marking gauge and waste with a chisel. On my last project with drawers I used mid 18th century construction as described by Jack Plane in the link below. I like this construction and will use it again.
http://pegsandtails.wordpress.com/2012/07/22/constructing-a-mid-eighteenth-century-drawer/
Some may balk at the cross grain construction, but I have not experienced problems in the last two years since it was built. My home is dry in the winter (I heat with wood) and humid in the warmer seasons (I use air conditioning sparingly).
Regards,
Paul Dzioba
Thanks Paul
I may use a router table for the groove in the curved drawer front - not used mine in many years, but it would be perfect for this task.
I have come up with a idea that will simplify the half-blind construction.
If you recall, this curve requires that the tail board have angles at the baseline and end.
It occurred to me that I would not need to angle the baseline - which is required for a gapless fit - if the pin area is squared first. That would make it easier to ensure the join is tight in that area.
Does that make sense?
Paul in NJ
Yes, that is what I did by rabbeting the back of the drawer front.
Great! I did not get what you meant earlier by "rabbetting". Looks like we are on the same wavelength.
