Re: my point.....
TomD
It certainly isn't because it isn't strong, it is a very strong wood, and it is rowed, so it does not split in situation where other woods do. We used to have a large elm, pre elm disease. It was horrible to split, and it was heavy, but weak was not the problem.
Speaking generally, splitting is not necessary for green wood working. It works because it is the most efficient means to an end. Whenthat stops being the case, a bandsaw if one has one is great. It is a myth that splitting yields straighter wood than sawing, though it work very well for that purpose at times. In any case, elm is so strong and hard to split, a little run out wouldn't affect the end result, though it would complicate some working.
