Cabinet Build progress
Brian Holcombe
Finishing up the drawer slips here;
Getting a nice shiny finish
Making stub tenons to locate the sides
Still debating the drawer liners. Might do leather, might do something else.
Getting closer....
Brian Holcombe
Getting closer....
questions....
or course.
What is the thickness of the drawer sides?
I don' t understand the drawer construction. I get the side slips, though I am unsure of their necessity on these small drawers. I don't know what the slip-like piece is in the front of the drawer. In one picture there seemed to be a groove there for the bottom to fit in but then it seems to have been filled by some piece I don't understand the purpose of.
Is there any chemistry concern with a leather liner that metal jewelry will sit on? Leather can be tanned with a wide variety chemicals, some of which stay in the leather and some of which promote corrosion. I am ignorant of buying leather. Can it be bought where it will be assured of not promoting corrosion?
I'd consider velvet. Wrap it over poster board and glue the edges underneath. Insert in drawer.
It is a lot of drawers but I would have considered solid bottoms made from some light weight easy to work wood- pine or basswood. I would have left these bottoms not finish planed, that is , showing some tool marks on their bottom for some knowledgeable person to discover some years hence. It is a nice touch on the old English drawers to discover the thin pine? hand planed bottoms. They can be quickly made if one is not fussy about the finish. And one should not be fussy about the finish of a drawer bottom.
nice!
Tony - Memphis
Your work is so nice and clean and crisp! That's how I IMAGINE mine to look before I get started...never happens though!
PS
There is an alternate to the extra labor of making the tenon on the end of the slip. The purpose of this tenon is for indexing the groove in the slip on the drawer side with the groove on the drawer front. This indexing can be done with a small, say 2 x 2 , square of wood the thickness of the slip groove. Insert indexing square, fix slip to drawer side with nails or glue, then remove indexing square.
BTW how did you fasten slips to drawer sides.
what are you making now days
Re: PS
Brian Holcombe
Thanks Gents!
Bill, I glued them in. Not sure where you saw a groove previously, but the drawers werent grooved.
I debated skipping the front drawer slip, it's a bit redundant with a drawer front at 3/4" thick....but I made a boo boo with the drawer bottoms and decided this would cure all without having to purchase a new sheet of plywood.
The sides are 1/2" thick.
I tend to agree with you on the pine bottoms and you'll probably see some interesting changes in future case goods.
I have another two case goods coming up, one of my friends wants me to build him a bar cabinet (similar dims to this one but far fewer drawers) and my wife has me building a wall hung shelf with drawers.
I see my mistake
PIC 3 I thought the groove was in the drawer front, but now I realize the skip has been applied.
BTW, basswood makes dandy drawer bottoms, as does white pine. I am not a fan of yellow pine but many use it.
Note on drawer linings
Wiley Horne--So. Calif.
Not sure what kind of jewelry is envisioned for these beautiful drawers. However, I thought I would mention a product I have used for silver jewelry, and which really does work.
Pacific Silvercloth:
https://www.silverguard.com/default.aspx
The cloth itself does not have a velvety feel; it's a bit stiff-feeling, being impregnated with silver, and comes only in brown. But it keeps silver bright forever (as best I can tell).
FWIW,
Wiley
Re: Note on drawer linings
Brian Holcombe
Thanks Wiley, she does have some silver so that's a great idea.
