New WoodChat!
Framing Ichikawa
Framing Ichikawa
Framing Ichikawa
Brian Holcombe
Ichikawa Ebizo IV as Takemura Sadanoshin is the subject of this portrait. This work is part of the short lived career of Toshusai Sharaku, a ukiyo-e artists who is famous for honest and realistic but unflattering imagery. The speculation around his career suggests that it was short lived partially because his work was met with such immediate disapproval. Most work of the era would represent their subjects in idealistic manner.
This is not an original woodblock, but rather a reprint created in the early 20th century. One of the things I find very enjoyable about Japanese woodblock prints is that they were meant to be accessible, the sentiment as I understand it is that the general public should be able to own high art.
The finish I chose for this frame is a simple wax, and so a high sheen off the plane is required.
Cutting half lap joinery for the inside frame
Detailing the adjoining half lap shoulder to mirror the mitered inside edge
Re: Framing Ichikawa
I don't understand the engineering
I have never seen a frame made like this one. I do like the looks but don't understand what goes where if one were to dissect the cross section of the frame.
Re: I don't understand the engineering
TomD
It looks like a frame within a frame, presumably there is some further panel supporting the print within it. The outermost frame is a simple dovetailed structure like a drawer or a cabinet, it has a groove in it that holds a second frame that might be anything, but looks like a rail and stile thing like the door of a cabinet.
It is beautiful, but the exposed dovetails don't look Japanese to me, not that I am the arbiter of such things.
Re: Shadowbox
TomD
This style would make a nice shadowbox, if there was a glass panel cut in just to the rear of the front edge.
Brian Holcombe
Thanks Gents!
Bill, Tom is accurate, it's frame within a frame. There is no real hard backing, per say, since the art this size doesn't require a whole lot. Instead I used a foam art board that was white in one side and cork on the other. It's my understanding that one must take care to use 'acid free' supplies when mounting. This is not a particularly expensive artwork, but I like to always take precaution.
Tom, I believe the traditional mounting is on a scroll, so my aim was far from traditional. The interesting thing about traditional Japanese work is that it sits so nicely with modernist work, in my opinion. Many of the modernists were taking ques from traditional Japanese work so that does not come as a complete surprise. I'm about 80 years late to being a modernist, but I feel my work has similar inspiration and similarly is through a western looking glass.
Acid free
John in NM
That is correct, if you use regular old cardboard products the paper of the artwork eventually turns brown and crispy. Artwork need not be rare or valuable to warrant the effort, as long as it's something you like looking at it's worth your precautions :D
so...it is the inner frame that fits in the dado of the outer frame?
Is this frame something you came up with or is it common to some period or culture (I don't get out much). I do like it.
Brian Holcombe
Thanks Bill, exactly it fits into a groove in the outer frame.
This is something I came up with, an experiment of sorts...so far so good. I've framed a silk screen print in a similar manner.
Very nice!
Tony - Memphis
Very crisp...nice work! Your dovetail sockets look so nice and clean! Mine look like someone hacked them out with a butter knife.
Tony
JDK
Have you thought of mitering the inner frame instead of using half-lap joints?
Brian Holcombe
Thanks for the question, I love this board you guys always ask good questions.
I prefer half laps for this, they're less refined in appearance and more suitable to my mostly rustic work.
With all of my work I feel it must fit in with the other work I have around the house....which is a double edged sword. I've been tired of maple for quite some time but continue to use it for frames I build for around the house so that they match the existing frames. I try not to slavishly adhere to it, but minimal departure.
JDK
It's an attractive design. I'm going to reproduce it this weekend, but I'll be mitering the inside frame and mitering the dovetail joints as well.
Quite impressive, Brian.
Brian Holcombe
Excellent, if you would post up a photo of your results.
I'm curious to see the art that you choose to frame this way (if you dont mind sharing, I understand hesitation of posting art on a forum) because I am curious to see what sort of forms people lean toward for various styles of art.
For what little it's worth
....my opinion that is. What attracted me to the frame was it was not conventionally mitered. Novel usually fails to impress my conservative eye but this design worked...so I concluded. It turned an ordinary frame into something attractively novel.
I cannot imagine the frame in other than a plain light wood. I suppose rift cut ash would have worked but maple or maybe birch seems perfect for the job.
Re: For what little it's worth
Brian Holcombe
Thanks Bill!
I ended up sticking with maple for that purpose as well, these simple frames look good in it. I feel a dark wood or figured wood would have them looking too heavy.
TomD
The other thing is that in your particular purpose, framing a japanese print, the miter is not used, or all that common in their work, so it would not look right. I would call your result highly sophisticated not rustic at all, and not improved with a mitre. I tend to associated mitres with a lot of cheapness, though that is just me.
A mitred dovetail is a challenging enterprise though.
TomD
Well said Brian, and you gave it beautiful expression.
Brian Holcombe
Thanks Tom!
I always find myself searching for a good descriptor when attempting to describe work of this vernacular. You're certainly correct in 'rustic' being a poor description of it as none of it is really rough hewn or anything of that nature.
