Re: Indeed yes and plane blanks
TomD
Depending on how you cut the tree, a flat sawn piece cut out of the heart, heart aside, is quarter sawn/radial, and anything outside of that piece in slices above or below it is pretty much riffed.
Pictured is a flat sawn log. Depends on the scale, is it 24 inches, or 12. But on a large piece, there is plenty of usable wood to either side of the pith and the middle 20 percent vertical section.
If you look at the central pieces (the three to nine o'clock pieces) they are quarter sawn, other than some wood at the center. If you wanted to bother, you could also take out the vertical wood above and bellow the pith and get more radial pieces that are what we call quarter sawn.
In a quarter sawing routine the wood is handled so the radial material is taken out like a cross as described above, then the quarters, awkwardly shaped, are also radially sawn. (the diagram below incorrectly equates quartering with riff sawn wood)
But here is the point. When buying wood, radial (quarter sawing is a method that yields all radial wood, the resulting boards are radial) is either expensive, or often unavailable. It seems scarce as though nothing would be better than sawing all your wood into radial form. But if you can saw your own wood, the wood available that is radial when you flat saw, is usually sufficient for most purposes. It depends on the design, but most cabinets may have more "pretty" flat or riffed wood in them, than they have parts like stiles and rails that are best cut radially.
Here is the kicker. If you saw your wood flat, but as Bill says saw it THICK, then the flat sawn pieces that are outside the core and basically riffed on the outer edges but flat in the middle, can have the centers resawn so that they yield 2 inch radial wood for stiles and rails, etc... By keeping the wood thick, you set the wood up to dry flatter, and to allow you to decide what you are going to use it for longer. This works best if you can saw logs at least 16 inches in diameter. But the large stuff is a more efficient cut, and the resulting wood is more of a premium to those of us who work wood into solid wood furniture, with best results.
While it may take a while to get the wood into a usable state, normally by the time you are ready to cut the wood, and have found a ready supply, you have so much wood that you will never get through it in several lifetimes. For the first few years as you wait, remember all the greenwood projects, bowls, rakes, etc... you always wanted to do. After that, the avalanch of wood can be more of a problem than how long any new stuff takes to be added to the pile.
By the way, the house I had a picture of and it's "9000 dollar log". Their neighbour has a similar tree. And I know that neighbour well. There was a truck parked out front of the tree with a massive chipper attached to it today, with a guy in the truck eyeing the tree while taking on his phone. Where it not for the recent bypass surgery, there would be a very real chance I would get so much wood out of that one tree, I wouldn't see the floor of the shop for a decade.
