Cut-and-Pasted demonstration.
I am making 2 mirror frames with white oak and need to make stopped rabbets that are 1/2" x 1/2". My process was to cut the rabbets at the router table, then I needed to square the ends so I got out my trusty Marples (I know they aren't the best, but it is what I have) chisel and mallet and chiseled out the ends. After completing 4 ends, my once sharp chisel is ready for some major resharpening. There must be a better way to do this that won't kill a chisel this quickly. What is the preferred method for doing this? TIA
I wrote the following about the stopped rebates in my current build - easier just to copy-and- paste. Apology for being lazy.
Of note, the frames here are curved, not straight - just another little complication.
Not really significant, but just for reference.
A warning about the rebates – they are stopped rebates, which is risky to do and not generally recommended for this type of construction. The rebates terminate short of dovetails that lock the two sides via the top rail. It is easy to weaken and damage them. The only reason I am going down this route is to maintain a clean exterior – I want to finish the back of the chest at the same level as the front. The joint will be strong (again) once the parts are glued up.
This is where the rebate will go …
The plan is to use a rebate plane. Those who have tried this are aware that planing from one end to the other will create a curve, with the depth deepest in the centre of the side, and tapering off to the ends. Eventually the plane will stop cutting ..
To plane this successfully, first remove enough waste from each end to enable the rebate plane to continue planing to depth ..
Do the same at the other side …
Now you can plane with confidence as the rebate can be taken to full depth along the whole length.
Those familiar with the Veritas Skew Rabbet Plane will notice that the front knob has been removed (as well as fitting a deeper sub-fence). The knob seems superfluous to me since I cannot find a reason to use it. There is far more control pushing the plane into the rebate, that is from the side.
What I have discovered is that the place where the knob went makes a handy position for the thumb – better than the fence alongside the edge of the blade … where inevitably I cut myself!
This is the completed rebate. The rear panel will sit in a frame that fits in the rebate. The sizing of this rebate enables the rear sliding dovetails to be sawn inside it and then hidden behind the frame.
