Re: Left handed planes
Joe in a Cleveland suburb
Hi guys.
Just wanted to follow up on this and ask a couple questions.
I received this little 3/16" beading plane last weekend. Without cleaning it or sharpening it, I put a stick of pine on my bench and tried pushing the plane right to left using my right hand to push and it was no big deal. Then I tried left to right on the far side of the stick pushing with my left hand; same thing, no big deal. So my worry of being left handed is nothing to worry about - seems I can do it with either hand. Just like batting. I stunk batting left or right btw....
So last night I cleaned the grime off and flattened the back of the iron. I took a bit of (I think it is) 15 micron paper wrapped around a drill bit to try to sharpen it a bit. Seemed to work ok although there is a small chip in the profile I noticed.
When I put the blade back into the body I noticed there is a lot of side to side play. In other words the iron is much narrower than the body. Is this normal?
As I looked closer I also realized the profile on the iron does not match the (boxing?) profile of the plane. The profile on the blade is larger than the profile on the plane itself. Not good, right?
I would guess trying to make a new iron is not worth the effort. That and I have zero metal working knowledge or skill.
I guess you get what you pay for. At least now I have a better idea of what to look for when buying an old beading plane.... Oh, and I learned using my right hand should be an issue. So its not a total loss.
Thank you.
