New WoodChat!
Millers Falls Spiral Screwdriver Repair
Greg Krummel
I recently acquired a Millers Falls No. 61 spiral screwdriver that occasionally binds in the ratchet. While trying to open the ratchet mechanism from the front end I reached a part that was threaded into the body (Number 21 in the patent US 1578866 A, and picture attached). The part is seized, and I tried to free the threads with penetrating oil and torque on the slots with no luck (it appeared whoever last tightened the tool applied enough torque to mushroom the faces of the slot).
Does anyone happen to have ideas or experience of how to remove this cap, or if there is another way to access the ratchet mechanism for cleaning and inspection?
Thanks!
Re: Millers Falls Spiral Screwdriver Repair
Not specific to this situation but
Chuck Nickerson
I often have good luck applying heat in one of two ways. You can use a torch or heat gun (my preference) on the outside of the fixture OR apply a high-wattage soldering iron to the part not turning.
The metal's expansion due to the heat is often differential enough to break the bond.
