Re: Yes, but...
TomD
I agree, the metal guys in different trades all act as though what is common knowledge in another field is magic, yet they are full of misinformation about the problems.
I think the info Bill got is largely accurate as far as some of the process and results, but brazing should yield good results. Welding is knitting the crack together with the material in the plane or parent metal that is more of the same, we are taking white hot in the heat affected zone. Brazing of the hard type is over 800 degree use of flux and bronze of silver braze to flow into the crack and pores of the metal, to create a strong bond, it should be OK for this kind of repair. Often guys who weld on the farm are proficient, because a lot of old tractor crap is cast.
Certified in welding terms is more limited than it may sound. My understanding is it means they have a ticket for a particular process, like welding a pipeline pipe, an aircraft frame, or a nuke tube. Passing these test is some serious skill, but you might find an advanced hobbyist who is more generally skilled on a wide range of materials. There are a lot of welding gurus out there who through a career have multiple certs, and an inquiring mind that leads them to ask a lot of question and become very broadly knowledgeable, which is always and interesting conversation when you get one. I remember a guy a few years back who claimed to have cracked the code on welding overthick materials with a Dynasty 200 tig. That is a rocketship of a welder, but nobody believed him, and I never heard the end of it. But the discussion was so far above my head I couldn't see them talking on the other side of the clouds. It can get seriously complicated, and the processes are a lot more complex than a sharp thing in a bed, with a crack over it.
That said there are specialty areas that break the rules. Hand built bikes are essentially made of aircraft chromoly tubing. It is dogma that you can't braze that stuff, and for good reason, yet the bike guys traditionally brazed their frames, but they didn't crack as a rule. There are many examples of that kind of thing, and we have had research scientist level metallurgists on some of these boards telling use stuff we do every day can't happen.
