New WoodChat!
re-toting a #8
re-toting a #8
re-toting a #8
Jerry Gibbs
Friend was given a #8 plane. It is in good shape (who over uses that big a plane?). He thinks the tote is too small for his comfort and is losing interest in rehabing the plane. The tote has a machined bed it sits on and needs to be close enough to work the alignment lever. I have included two pictures which have a 6" scale. He would make a bigger tote if it could work. Thanks, Jerry
Re: re-toting a #8
Re: re-toting a #8
Hi Jerry
Firstly, you can make any size handle (Tote -- aggh!) that will fit. However, the handle is missing the horn, and this may make the grip area smaller. Add in the horn, and the size may become acceptable.
Secondly, the reason that this looks restricted at this moment is that the adjustment lever appears bent over the handle. It needs to be straightened up. Once done, if you choose, a taller handle could be fitted.
Re: re-toting a #8
Re: re-toting a #8
David Charlesworth
Is he aware that Stanley handles are used with a three finger grip?
The forefinger is pointed forwards.
David
