Re: Question for you
Hi Ellis
Good question ... AND this gives me an idea (no doubt you have already considered this!
I went back-and-forth on this a while back. The advantage of one piece (front blade shaped to fit inside the drawer front), is obvious - all in one piece. The disadvantage is that the projection on the sides (into the legs) is less easy to judge. I want the exterior of the drawers to end 1mm inside the legs. The bow on the drawers will become less as the drawers become narrower.
Here is the bow for the lower drawer (the same curve is for all the drawers, calculated from the centre) ...
What I had planned to do is add a filler to each drawer - just make one or two thick pieces and slice off enough for all the drawers.
What is also possible is to add the bow to the existing front drawer blades, extend the sliding dovetails by the 2mm at the ends I planned to add on the filler pieces, and slide them forward into position. That would be easy. However, the bow is about 5mm at the centre (from memory) on the large drawer, and there will be shifting back-and-forth to get the projection the same for 22mm thick drawer fronts.
Your thoughts?
