Wiley's Pattern..
david weaver
...yeah, nothing new. Another one of a similar plane, and last one for a little while maybe. I can't stop trying things, but sometimes they don't turn out the way I want.
I call it wiley's pattern because wiley made a generous gesture and put a spare matheison jack of his in my possession which gives me both a handle to copy and the right proportions and locations of things.
Maybe copy isn't the right word, it's not a dead copy, but heavily influenced by.
I thought since this isn't going to be my plane, that I'd make the wedge a bit laterally undersized at the top, but tight at the tips of the fingers. I think it just looks like it's the wrong size. I made it short so it would be a while before it had to be cut to adjust the iron. It doesn't look terrible, but a lot of these planes have very bold wedges that are square all the way to the top and large. I'd make it taller and wider if I did it again. You can see from above, having the gap just doesn't look right.
Also, a stray float stroke made the mouth not as tidy laterally on the bottom as I'd like, but that picture didn't come out right, so it's not shown. It's got a couple of things like that are the kind of things that torture you when you just want to make one just right, but I'm sure it will work fine.
http://s3.postimg.org/71f62gk03/20150926_143229_1.jpg
http://s21.postimg.org/elw3ln15z/20150926_143241_1.jpg
http://s14.postimg.org/4zu7sstch/20150926_143256_1.jpg
http://s27.postimg.org/arvt3cymr/20150926_143330_1.jpg
The light stripe down the middle is the transition from heart to sap, sometimes it's really distinct like this. I think it looks neat, but over time it will all become the same color.
Thanks, Wiley! It's so nice to have a decent plane to start from.
David has been kind enough to make these planes for me ( this jack and try plane) After some discussion on the merits of wooden soled planes, which at the time was only in the abstract for me. I had been yearning for a combination of planes that would make my work on panels and tables a bit easier to accomplish. The try plane zooms through the work and without a heavy camber or waxing every few passes. So after having put that to work I was definetly wanting to experience that same effect in every aspect of the process.
; you did fantastic in your adaptation.) David's revival of the olden tyme woodies is a great contribution, and one which will last.
