New WoodChat!
paring chisels
paring chisels
paring chisels
Rick Snyder
I recently purchased a set of paring chisels made by NAREX. What is the best angle/ degree for this type of chisel ? The Q&A article ( FWW online) mention micro bevel and secondary bevel. How do they differ from each other and which one would be the best?
Thanks, Rick
Re: paring chisels
Re: paring chisels
david weaver
It doesn't matter too much how you arrive at the final angle (either by secondary bevel or by just using one bevel), set them up with the lowest angle where they still hold their edge well. that'll probably be around 25 degrees, or maybe a touch more with those.
If you're paring only pine, you can go lower.
If the edge dents or rolls, increase the angle a little bit. Same if it chips.
My personal preference for setup in a paring chisel is to have a long thin primary bevel and a secondary bevel slightly steeper. Then it's easy to adjust the secondary angle if the chisel needs to go a little steeper, and easy to get rid of it if you want a little less steep.
Re: paring chisels
Re: paring chisels
Hank Knight
Rick,
I think "micro bevel" and "secondary bevel" are synonymous. They refer to a slightly steeper, very narrow bevel that some use at the very tip of the primary bevel. The theory is that it's easier to touch up a narrow secondary bevel on a strop or a fine stone than it is to hone the entire primary bevel. A slightly higher secondary bevel may also help with edge wear because the higher the bevel angle, the less chip-prone the edge is. If you have a 25 degree primary bevel and add a 3 degree secondary or micro bevel, the resulting bevel angle at the cutting edge (where it counts most) is 28 degrees. The trade off for greater edge durability with a high bevel angle is that the tool is harder to push through the wood. This is why most paring chisels have a lower bevel angle than work-horse bench chisels, I.E., because they're pushed rather than struck with a mallet or hammer.
Re: paring chisels
Re: paring chisels
Hi Rick
David's suggestion is good. This would enable you to find the best bevel angle for the steel in these chisels.
Paring chisels are typically 25 degrees, and sometimes lower depending on the wood. It is always a compromise between ease of entry (lower angle) and durability of edge (higher angle). Bench chisels are typically 30 degree, since they are struck, and mortice chisels, which are struck harder and deeper, are around 35 degrees.
In the end, the type of bevel does not make much difference. A sharp end is the important factor, and there are as many sharpening methods and preferences as there are woodworkers. What you do with the chisel is really what counts. Some prefer a secondary bevel, either via a honing guide or freehand. Others will hollow grind the bevel and hone on that.
