New WoodChat!
A55 Smoothing Plane
Moravian Bench Build
Our club president Rick Foltz tries out the bench for the first time.
The club needed a portable work bench useful of a wide variety of demonstrations. A work bench patterned after a Moravian bench at MESDA seemed idea. A group of club volunteers set about to make one. Most had little woodworking experience. The project involved selecting lumber, planing it, and gluing up the top and legs. To assemble the legs, bridle, mortise and tenon and dovetail joinery was done, largely with hand tools. Tusk tenon joinery was done to secure the leg stretchers to the legs.
The bench disassembles into the two leg units, two stretchers and the top which sits on locating pins.
In this instance the use of hand tools was chosen so that I didn't need to worry about these novices injuring themselves on a power tool.
The bench is amazingly stable. If anyone needs a portable bench this bench would be a candidate. The bench in the picture is 42” long and 18” deep.
Re: Moravian Bench Build
It's on my list...
John in NM
I now have a house up here at work which has a small garage, so this bench is in my immediate future. Just got to get up to Santa Fe for some 10/4 leg stock.
As someone asked on the other side, where did the vise end up?
Legs
Glue up the legs and you can cut dadoes in the legs that will become the angled tusk tenon mortises when you glue them together. When you glue, cut a block the size of the tenon, wrap it in handy wrap and place in the tenon to-be to align the leg halves to make the mortise. There legs were made 3 3/4" just for weight. 3" would look better if you don't need the weight. I was amazingly rigid when we did some test planing and it did not skid on a finished concrete floor. Some non-skid pads on the feet and it would not skid on any floor.
With a removable top the vise had to go inboard of the left leg. If the top was fastened it could go outboard.
If you buy a Jorgensen vise (Woodworkers Supply) the vise comes apart leaving a much lighter weight part fastened to the bench top. Makes moving the top much lighter.
Re: Legs
John in NM
Glued up is always an option, though I typically avoid it if I can. Hadn't thought of those angled mortises though, that might just tip the scales well in favor of it. I've got three old vises at this point, so I'll likely use one of them, which one is going to come down to how portable I want to make this. Portable is not a requirement for me, but then I may not stay in this house more than a few years.
Re: Legs
In our case the bench will be moved, set up, taken down at least every month. So our details are different from yours. Personally for your need I would do a bench with straight legs, M&T, and draw it together with bed bolts like a bed frame. This arrangement is as stiff as it gets. I made a loft bed with 6' legs and when the bed bolts are tightened it doesn't quiver.
Charly
I love it. Hope you didn't dare scrape or sand any part of it.... ;)
