New WoodChat!
200+ woodworking book reviews
Rust prevention
Rust prevention
Rust prevention
Howard Pollack
I'm setting up a new shop about a mile from the ocean. The humidity is always high and it is often foggy. I'm concerned about keeping tools rust free. Other than coating them with oil I wonder what else I can do to protect them. Thanks.
-Howard
Re: Rust prevention
Trivial solution
Keep the shop relative humidity less than 65%. You face no greater problem than those in basement shops. When warm moist air sinks into my shop, or moisture penetrates the walls, and the humidity goes up the dehumidifier goes on.
Re: Rust prevention
Re: Rust prevention
TomD
I use Camellia oil on hand tools. A little goes a very long way, it isn't nasty stuff so I tend to use it. There are more effective products, but they don't seem to be necessary. Bill is correct about humidity in that there are conditions that are necessary for reliable woodworking, and once met, most rust problems disappear. Making sure overhead pipes are sheathed in foam and don't drip once a year when you least expect it, is worth the trouble. I also find certain materials are a lot less likely to rust. Cast iron tools are occasionally trouble, unless they live in a bath of oil, as do my metal working tools.
I ran into an odd problem a few years back when I added so many metal working tools. Up to that point I could throw open the doors and let the warm seasonal air in without risk of any real problems. Apparently I now have reached such a critical mass of cold objects in the shop that I can never open the doors to the weather without a risk of everything getting covered with water. I finally solved the problem by using a fan to pull hot air out of the roof for heating, which is an overall plus from within the envelope, though I do miss having air flow through the shop.
Re: Rust prevention
Re: Rust prevention
Curt Putnam
Corrosion X HD protected my cast iron tool tops for 5 years of disuse - just out there in an unheated garage. Everything that was not similarly protected rusted. Now I spray some on a rag and wipe off tools when they get put away. I love it. It is petroleum based so may no fit your criteria.
http://www.corrosionx.com/corrosionx-heavy-duty.html sold by Amazon.
As long as your shop temp is comfortably above the dew point you should not have too much a problem.
Re: Rust prevention
Re: Rust prevention
William Duffield
I have no issues with the use of camellia oil as a rust inhibitor. It works like a lot of other edible vegetable oils. It is very similar in composition to olive oil and sunflower oil, with a high percentage of oleic acid. There are differences that might be important from a nutritional point of view, but not when coated on your steel and cast iron tools and machinery. Maybe it's the antioxidants? The brand I use comes packaged in a plastic bottle with a spritzer, which is convenient.
The bottle is also covered with Japanese characters, which like the labels on Japanese water stones and white steel chisels, I can't read. Maybe the Oriental mystique makes it a lot more valuable, and is a valid reason for commanding such a high price, but I'm skeptical. Why not use olive oil from your pantry? For about the same price, you could get two liters of Kirkland Signature organic extra virgin olive oil, or a lot more of some mediocre generic oil. Sure, there are boutique EVOOs that are even more expensive than the camellia oil, but you're even less likely to smuggle them out to the shop than your wife's steam iron.
Re: Rust prevention
Re: Rust prevention
R. Payne
Keeping the humidity down will help but that close to the ocean means higher levels of salt components in the air as well, the surest way is a very light oil coating. I'd just get a big jug of mineral oil, put a bit on a rag and wipe after use, it only takes a little. If the rag has only a bit on, it won't be enough to affect the woodworking or finishing. I'd be wary of rust preventatives that contain silicone etc.
ron
Re: Rust prevention
Re: Rust prevention
TomD
I think a lot of people would agree with you William that Camellia doesn't do anything that some other oils might not also do. It works better for me, not in the sense of rust protection, it gets that done. It just works better as a product. It is very light it works into the skin, and I don't have to worry about cleaning it up, or whether my glue joints will fail. I would say unlike those other products you mention it is designed for this use, except that if i could read the Kanji, it would probably turn out to be hair oil. :)
Cost is immaterial, it ran me about the same as a can of WD40, and nobody borrows it to do stuff it isn't designed for. I spilled a chunk of it and I still have a lot of the original bottle purchased in the 80s. I bought a large refill bottle and one of those cotton stabbers, but I don't use it. My experience so far has been that in many situations in my current shop stuff doesn't rust but if the tools feel dry or wet, I just rub a smear of this stuff on them and I don't have a problem, so I seem set to pass on at least some of this stuff to the vultures that come to devour my shop when I am gone.
Re: Rust prevention
Re: Rust prevention
TomD
I don't doubt that works, but one of the reason I use camellia is because it feels good on my hands, and I can just smear it on without needing an applicator, and go right back to working. I really don't like oil and rags in any situation, and fire aside If I knock it over I don't like the mess on concrete. I guess we all have stuff we prefer to avoid.
Ebay is full of free delivery offers under the health and beauty sections for 100% pure, and under 10 bucks. I don't know if we really know what is in that stuff, any more I suppose than what is in the virgin olive oil that doesn't behave like virgin olive oil. So I suppose on chooses one's poison.
I have machine tools and they get actual oil all over them. I just use the camellia on my hand tools.
Re: Rust prevention
Re: Rust prevention
R. Payne
Any light oil should work. If you like the camilla and it work then you've got your solution. I like having just a little on a rag because it doesn't overdo the oiling as just a small amount is needed and an almost dry rag doesn't overdo it.
Different strokes and all.
ron
Re: Rust prevention
Re: Rust prevention
Jim Matthews
It's a problem for most of us, this time of year.
I prefer passive solutions:
keep tools in a wooden drawer, where possible.
Use dessicant packs (I prefer the reusable type).
I have migrated to wooden body planes, because of the endless rust forming on my
nice cast iron tools. If you don't like oiling your tools, keep them in the VOC bags designed to inhibit rust.
Re: Rust prevention
Re: Almost
William Duffield
Almost any light oil…
You probably wan t to steer clear of linseed, tung and walnut. :)
Re: Rust prevention
Re: Rust prevention
Howard Pollack
Thanks to all of you. -Howard
Re: Rust prevention
Re: Rust prevention
Bruce McCrory
I live a couple miles from Puget Sound. We are either wet or in drought, but always humid. I had a Lee Valley Veritas turn the color of Wood Central's background in a couple months time. Fluid Film, which is good old wool fat (Lanolin) works great. The manufacturer flaunts its Navy contracts. I have generic grease, too, but the spray gets into tight nooks. No obnoxious toxic fumes and great for chapped hands.
My tools and work are in an unheated garage. One of my friends leaves his table saws out in the open. Just throws a plastic tarp over them. I thought he was too lazy to scrap them.
Re: Rust prevention
Re: Rust prevention
TomD
"I have migrated to wooden body planes, because of the endless rust forming on my
nice cast iron tools."
There are lots of reasons to prefer them, but I did get a real kick that helped confirm my preference when I moved to a new shop 20-30 years ago. One box sat in a little water for a short period of time, and a Lee Valley (before LN) plane that was a bailey type made to very high standards, ended up encrusted in rust. It's not like they work better or something, so why put up with it.
I forget how it happened that it got in the water, I know it wasn't directly my fault which sorta set me up to thinking that if I couldn't even stop it from happening, maybe it was better to not invest in cast iron.
