New WoodChat!
Dent removal
Dent removal
Dent removal
I am such a klutz much of the time. Trying to do things too quickly .. knocking over parts, or even a completed piece. Don't you hate it when you do this, and dent an edge?
Step #1: wet the section (or not - not as important as the next step, but this wood is hard) ...
Step #2: use a wet cloth and a hot iron (I have my own, discarded from the house, and kept in the workshop) to steam the dent out ...
Step #3: a light scraping and there is little evidence of the insult ..
Re: Dent removal
Re: Dent removal
TomD
Guitars are a whole other nightmare. Carpeting everywhere, never too late to blow the whole project, or at least to make it slow down a lot.
Re: Dent removal
Re: Dent removal
I use a soldering iron.......but then I may not be dealing with dents as large as an iron can accommodate :)
Re: Dent removal
Re: Dent removal
Alex Grigoriev
http://www.amazon.com/Clover-Mini-Iron-The-Adapter/dp/B001CEAMH4
Re: Dent removal
Re: Dent removal
TomD
What with everything from x-country skiing to tailoring to stained glass, I have a few irons. Next one on the list is like this:
http://www.ebay.com/itm/HOBBICO-CUSTOM-SEALING-IRON-115V-170-WATTS-WITH-CLOTH-IRON-COVER-HOBBY-CRAFTS-/301710084263?hash=item463f5288a7
There are some vintage ones, but I forget the name.
Re: Dent removal
Re: Dent removal
don stephan
Wondering if some woods are not good candidates for this repair. Once I steamed out a dent in face of a soft pine board, and later used waterbased dye stain. The steamed area lifted up much more than the surrounding wood, and sanding flat of course removed almost all the dye stain.
Re: Dent removal
Re: Dent removal
William Duffield
A new steam iron is really cheap. Don't even think about borrowing one. It's just not worth the risk.
I keep one in my shop. IIRC, it even has a Teflon coating. In addition to steaming out dents, it is useful for sticking veneer to a substrate. I've used it for that purpose with both hot hide glue and Titebond I.
