Re: What angle C/B front edge
Hi David
The initial implication from the video was that 80 degrees should be used since that was the most successful angle used. However, as I recall, the planing was successful down to 50 degrees. Consequently 50 degrees became the number. Keep in mind that the planing angle was 40 degrees.
My own experimentation tentatively suggested that there would be a relationship between bed angle, the angle of the chipbreaker's leading edge, and the distance from the edge of the blade. Kees went further with this and demonstrated something along these lines (I am not sure of the exact findings - the excellent article is on Steve Elliott's website). Kees recommended a 45 degree angle at the leading edge.
I think that one is safe using something around 45-50 degrees. One has to play around anyway. There is no exact recipe for perfect results.
The angle at the leading edge of the Stanley is around 45 degrees (it is rounded as you are aware), while the LV and LN both 25 degrees.
I add a 50 degree leading edge, regardless of bed angle (BD planes range from 42 - 50 degrees).
Of the chip breakers on the market, my personal preference is the LV. The LN looks similar but it has a significantly smaller "ledge", and one must be careful how much steel you remove when honing the angle at the leading edge. A microbevel of about 1.0 - 1.5 mm is about all one can add to the LN ...
LN at left, LV on the right ...
Others prefer the Stanley. However I find the examples I have to be very flexible, and one runs the danger of their creeping over the blade. No doubt experience helps here, but the more modern LV and LN hold their placement more easily.
One of the criticisms of the latter is that they lack the curve of the Stanley. I have added a curve to a LN chipbreaker, and will report on this later.
